removing glue residue Options
ronald305
#1 Posted : 11 August 2017 16:14:50
Hello there
would anyone know how to remove glue residue after removing planks for formers
or ribs, reason why sadly I had to remove all planks from model something wasn't
right in the bow area and gallery support thank you
Ronald
z8000783
#2 Posted : 11 August 2017 17:49:13
Groups: Unapproved
You could try soaking in warm water, that usually works. I tend to use a course grained glass paper, 120 or even 100 and run lightly since you don't want to remove any wood.
ronald305
#3 Posted : 11 August 2017 18:32:12
ok thanks John
you right about sanding lightly as far as the warm water part do you
mean using a towel dampened in warm water
Ronald
z8000783
#4 Posted : 11 August 2017 19:28:34
Groups: Unapproved
Depends what the part are. Can you soak them separately?
