Joined: 03/02/2015 Posts: 457 Points: 1,389 Location: Crawley, W.Sx, UK
Hello to all! I am just about to fit the Artwox wooden deck to the foredeck of Trumpeter's HMS Hood. In the instructions (please see photo) it says to remove kit mould (red zone). If I do this won't this spoil the model as these sections are raised? Artwox provide PE parts to fit into the existing deck but they are not raised. Has anyone fitted these decks? Thank you Alan ALW attached the following image(s):
Hi Alan, I`ve not fitted these particular upgrade parts, but the idea is the same with many brass etch upgrade sets. When you remove the molding from the forward deck, all you are removing is the raised detail. This will leave you with a flat deck in those "red marked" areas. Then when you add the brass etch to the flat deck, you will have raised areas where the etch is added. The brass etch is fitted onto, not into, the deck. The brass etch should have sharper definition of the detail for that area than the plastic had. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Often they supply alternative anchor chain to replace the chain moulded on by the manufacturer, it is likely they won't you to remove any moulding. the two little red rectangles are likely to be the chain stay mount points which may be on the etch chain. look at your build instructions with the etch and see what is done in that area, should help you work out what to do. Is this the 1:350 kit? if So I have built it and its very good indeed Enjoy Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks Derek, Thanks Jase.
I guessed that's what needed to be done so treated myself to a Dremel for the task!
Jase, this is the 1/200 scale version. It's huge!
Thank you both once again. Your input is very much appreciated.
Regards.
ALW wrote:Thanks Derek, Thanks Jase.
Regards.
Alan No problem Alan, One word of caution though. Be very careful with the Dremel, it will eat plastic. Careful work with a scalpel is much more controlable. Good luck Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek
Your comments are noted. I tried it on an old piece of sprue. It's fairly controllable at it's lowest speed but I will be mindful.
Luckily I just happen to have a second foredeck kicking around so if I do make a mistake at least I'll have another chance!
Cheers
I agree with the above the drivel will be to fast and will effectively melt the plastic with the friction even at the lowest speed. best advice is to scrape the detail with a sharp craft knife and then use an abrasive stick manually to finish off. I have the 1:200 scale on order so looking forward to the pictures of your progress Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
yep just go steady with it  but i usually scrape the detail off with a sharp blade ,but you`ll be fine  looking forward to see how it goes  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thank you for your replies. I will take heed from your advice and scrape it manually. I'm sure I can find some use for the Dremel Regards Alan
ALW wrote:Thank you for your replies. I will take heed from your advice and scrape it manually. I'm sure I can find some use for the Dremel Regards Alan I am sure there are a lot of scuttles to drill out for starters then you can fill them with this and get some great looking scuttles, https://www.emodels.co.u...krystal-klear-mskk.html
The front end of the foredeck done-found it a bit nail-biting! At last I can move on. Thank you all for your suggestions. Alan
Great result on the deck Alan  well done  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks Phil
Too expensive to make too many mistakes!
Regards.
looks great “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
It looks so much better with the wooden deck attached, they really do make a massive difference
All lower decks complete. Really looking forward to building proper now.
Looks great, very nice work.... If you reduce the size of your pics to ensure they are no larger than 148kb then you'll find they will show on your posts. This also saves members from having to download your images to view.... Regards Alan
Looking very neat. Well done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thank you
I think it complements the overall look really nicely too.
Alan, With regard to image sizing I usually do reduce them sufficiently but I'm having a bit of a problem with my PC and can't work out how to resolve it but will be looking into it. I know it's a bit of a pain downloading each time so will get this sorted ASAP. Thanks for looking in.
Yep well worth it Alan  looks superb  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
