Hi! Options
RobPam99
#1 Posted : 07 August 2017 17:24:32
Hi,
New guy here. Robin. Retired U.S. Navy. Long time plastic ship modeler but I am looking at the new USS Constitution 1:76 Model and wondering if I have the skills to build a wood ship.
Thanks
Robin
#2 Posted : 07 August 2017 17:28:06
Hi Robin welcome to the forumBigGrin i would say go for itThumpUp lots of help on here for you BigGrin regards PhilCool
#3 Posted : 07 August 2017 18:31:39
BigGrin Hi Robin
Welcome to the forum, as a first wooden ship build I would not recommend the Conny as its aimed at builders with at least one period ship build under there belt.
A far better route would be to build the Victory first with its instructions aimed at novice builders and it will take you through the build from start to finish.
#4 Posted : 07 August 2017 18:44:57
Hi Robin, welcome to the forum
Metal Mech
#5 Posted : 07 August 2017 19:33:01
Hey Robin welcome to the forum. My name is Joel and I am the Forum Suppport Team member for the US. I am here if you need any help with any issue related to US side of the forum.
I look forward to seeing your progress on whatever kit choose.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
#6 Posted : 07 August 2017 19:59:25
Welcome to the forum Robin Cool
#7 Posted : 07 August 2017 20:26:26
Welcome to the forum.
Cool Cool Cool Cool
RobPam99
#8 Posted : 07 August 2017 20:27:28
arpurchase wrote:
BigGrin Hi Robin
So, is there that much differents between the two skill wise?
#9 Posted : 07 August 2017 20:30:45
Welcome aboard Robin BigGrin hope you enjoy your time with us.
#10 Posted : 07 August 2017 22:09:39
Wooden ship builds can be a learning curve for us all that use many different skills to be learned and enhanced, what I would suggest is to look at the various wooden ship builds on here including the official builds and then make your decision on what you want to build.
#11 Posted : 07 August 2017 23:26:36
Welcome aboard Robin, hope you enjoy your time with us on the forum.....Cool Cool .. Like Andy says, read some of the ship build diaries, especially the Victory. The instructions for the Victory were compiled with the complete beginner in mind and I don't believe you will find any better. These in conjunction with the Official Build Diary take you through the learning process step by step and are easy to follow. Reading other build diaries will also help broaden your understanding as to what is involved in putting these together. There is also a wealth of knowledge available on the forum to help you with any difficulties you may come across, all you have to do is ask and someone will answer. Whatever build you choose I'm sure you'll love the experience..... Cool Cool
RobPam99
#12 Posted : 08 August 2017 13:00:43
Thanks everyone for the advice! I am still leaning to the Conny because I have done the Heller Victory (I know plastic) and the 1/96 Revell Conny, so rigging I feel I can handle. I have worked with wood ships before just not plank on Frame. Solid hull types. So far this site is great and I am about to make the jump, just have to talk to the better half into this. Cost wise it's a bigger jump too. I have most modeling tool. What others tool are needed and recommended to start with. Like a Chopper I or II?
Thanks
#13 Posted : 08 August 2017 13:09:25
I think you`ve already got a modeling back groundBigGrin so there are different skills to learn but i think you`ll pick them up quite easilyCool so i` say no worriesBigGrin just take your time with it and read as much on other peoples work on here as a guideBigGrin for tools modelspace do some quality itemsBigGrin regards PhilCool
http://www.model-space.c....1502170780.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=146868596
#14 Posted : 08 August 2017 18:01:52
Thanks
Hello and a warm welcome to the Forum.
I have the first two packs of the Conny and from what I have seen so far there is not a lot of difference in skill set requirement between them. Genrally the HMS Victory has very comprehensive instructions which is why it is often advised to start with her, but the Conny instructions will be far better than if you were buying this kit of the self of a model store and there is a so much help on the forum you will be Fine. I am building along too.
I would not add any tools until you feel you need them if you are a seasoned plastic builder you will have the basics. you will probably need to make a base bard or keel clamp but thats all for now.
RobPam99
#15 Posted : 08 August 2017 18:30:12
Update! I did it! Got the USS Constitution 1:76 Model and if I complete this one with good results the wife wants the HMS Surprise!
#16 Posted : 08 August 2017 21:33:05
Hope you share your build with us
#17 Posted : 09 August 2017 09:58:43
Welcome to the forum, I look forward to your build diary, now you have made your decision. Good luck with you build. BigGrin
