8 Pages «<5678>
Gaeta Falcata (Gajeta Falkusa) by Jack.Aubrey, Marisstella, 1:20 Scale. Options
#121 Posted : 04 August 2017 18:32:44
Will you be sculpting any fish to put in the fish boxes Jack? I think that would be a very nice touch? Cool ThumpUp
#122 Posted : 04 August 2017 23:18:34
Love everything about his build Jack, looks fab....Love Love
jack.aubrey
#123 Posted : 09 August 2017 12:18:18
Considerations about the sails of the Gajeta . .
The Gaeta (Gajeta) Falcata (Falkusa) seems to be a very versatile boat. We learned how this boat can be used with two hull configurations, one with high sides, optimized for sailing and one with lower sides, most suitable for fishing with nets.
But its versatility also manifests itself in its sails. Let's think about them.
The following image shows three Gaeta configurations, from left to right:
a) sails with "high" main sail; the main sail is very high, probably suitable with light winds;
b) sails with "low" main sail; the sail is not triangular and mounts a beam even below;
c) no masts/beams and sails; configured with low sides suitable for fishing; the rudder has been removed.
The following image shows a Gaeta in configuration type (a); for my taste this is the most beautiful and majestic. And here we can also look at another variant: the double jib, interesting . .
Here below the boat is in the configuration type (b): lower sail, jib fastened half way on the bow beam, although we have seen that it can be fastened on the top of the bow beam. The main sail may seem triangular but seems to be rolled on the lower beam and for this reason doesn't look like in the image 01 . .
Here are other images with an apparently "low" sail but with a real triangular shape. Images 04, 05, 06 and 07. Let's say this is a new type . . we'll define Type (d); obviously this is another sails configuration !!
For now I have not found more configs, but it's not said that they do not exist.
For reasons related to the size (height) of the plexiglass cover for the showcase, although my preference goes to the sails type (a), I decided to adopt the configuration type (d).
The kit features pre-sewn, well-made sails. Unfortunately they are for the configuration type (a) and to transform them into sails type (d) there is some work to do: the main sail needs to be ex novo rebuilt. But here some problems arise: I do not have the same fabric and so I should also redo the jib; but I'm also a dud with the sewing machine, so the result could be bad if not worse.
So ? Simple, I will install the original jib and the main sail tied to its beam as in the images below . . With this solution I just need to cut the big sail to the right extent and the game is done; once rolled on the beam its wrong shape will no longer be visible . . Hyper-pragmatic solution . .
See you next time, Jack.
08 Alla fonda 01
09 Alla fonda 02
10 Alla fonda 03
jack.aubrey
#124 Posted : 15 August 2017 17:58:09
Tuesday 15 August 2017
I almost finished the buckets !! Now it just miss the painting of the brass handles with "gun metal" and they're over.
Today my wife did a very good job with sails that are almost finished . . I need now only to hold the wire knots with a drop of glue.
Two photos of the buckets where you can see also a small detail of a sail.
Goodbye, Jack.
jack.aubrey
#125 Posted : 17 August 2017 13:29:53
Thursday 17 August 2017
Having finally finished all the various detail components, yesterday and today I was able to begin working on the masts and its rigging. The pictures below show the work done so far . . far from being near completion. However, the goal is behind the corner, maximum another week, then it will be time to setup the beach of Comiso on the displaycase . .
See you soon, Jack.
jack.aubrey
#126 Posted : 18 August 2017 12:42:32
Friday, August 18th, 2017
The commissioning is in progress . .
The rudder installed e working fine . .
See you soon, jack.
#127 Posted : 18 August 2017 13:30:33
really is a top top job JackBigGrin very impresive workDrool regards PhilCool
jack.aubrey
#128 Posted : 22 August 2017 13:17:03
Tuesday 22 August 2017
At this point the model is practically finished . .
Now I have to prepare and apply the rope curls to add realism to the edges of the running rigging and then there is nothing left to do.
In the next days I'll focus on the setup of the displaycase basement, according to the idea I described some time ago (rocky beach, various accessories left on the beach, etc.)
Soon, Jack.
#129 Posted : 22 August 2017 14:15:38
One word: Superb!Cool
#130 Posted : 22 August 2017 14:31:56
Beautifull JackDrool Love regards PhilCool
jack.aubrey
#131 Posted : 22 August 2017 17:38:27
Thanks Phil W. and Phil for your very positive comments, thanks again, Jack.
Other new images . .
daffy09
#132 Posted : 22 August 2017 23:50:52
Absolutely amazing build Jack. I've been following this throughout and I'm overwhelmed with your eye for detail and your skill in putting it all together.
Happy building
David
jack.aubrey
#133 Posted : 25 August 2017 17:02:30
Happy building
David
Thank you very much, David, for your comment; thanks again, Jack.
Wednesday, August 23, 2017
I've finished with the last rigging details, like the rope curls at the ending tips of the running rigging.
With this last activity, the model by itself is truly over . .
Now only the display case is missing in order to close the shipyard.
#134 Posted : 25 August 2017 18:51:56
Stunning work and a pleasure to see....Love Love
#135 Posted : 25 August 2017 18:54:20
Excellent result Jack.
Cool Cool Cool Cool
jack.aubrey
#136 Posted : 26 August 2017 17:11:27
Cool Cool Cool Cool
Meny thanks for your positive comments, friends . .
Saturday, August 26, 2017
I put inside oars and a couple of accessories, just to understand that much of the material I prepared will be better if positioned on the (future) beach . .
The next images will show the model inside its display case . . probably by the end of next week, bye, Jack.
jack.aubrey
#137 Posted : 29 August 2017 13:39:23
Monday 28 August 2017
I'm working on the display case base . . In particular I'm preparing the so-called "beach". To hold the small pebbles of the Elba Island beach called "200 steps" I used vinyl glue, laid abundantly on the wood basement.
The work is not yet finished because I think it is better to make another layer of this sandblast and then apply the larger pebbles individually. . I now have two new sizes . .
Interesting experience. We will see how the situation evolves.
See you soon, Jack.
jack.aubrey
#138 Posted : 29 August 2017 15:47:32
Tuesday 29 August 2017
The display case setup continues . . Still a few days again . .
jack.aubrey
#139 Posted : 30 August 2017 17:41:47
Wednesday, August 30, 2017 - Finished
These four pictures show the finished project, under its plexiglass cover . .
Due to reflexions and low light the photos are rather poor, but they still make the idea of how the whole complex appears.
Now the adventure is really over.
A further batch of more detailed images, as my customary, will follow soon.
A warm greeting, Jack.Aubrey.
#140 Posted : 30 August 2017 22:01:47
Stunning result Jack, truly a joy to follow....Love Love
8 Pages «<5678>
This page was generated in 0.217 seconds.
