Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
Can anyone tell me how to post pictures on this forum directly from my Apple Photo Library.
Mo.
Mo
Hi Mo. Sorry but there isn't a way to directly upload from the apple library. The only way is to attach pictures to your post with the forums own host. You just need to make sure the picture size is 600x337 then it will upload no problem. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
On your post now if you look top right you will see attach, click that and it will then go to you library. Like I said make sure the size is right. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
