Very neat, looks fab..... Regards Alan
Joined: 04/10/2016 Posts: 135 Points: 412 Location: Newcastle U.K.
Looking great Walter. Keep up the good work. Alan. Today is the tomorrow you wished for yesterday!
Stunning work as always Walter Al
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Walter, Your attention to detail is admirable. Excellent. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
This is coming along quite nicely Will look stunning once its all finished
Nice work Walter she's looking grand. Well done mate. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks for your nice comments, guys! I`ve been on a vacation last week so i couldn`t post an update.
So here`s my recent progress.
I completed the gratings of the beakhead - wanted to achieve a flat platform.
As there was some angle between the beakhead-frames i corrected that for the beakhead main rail to be able to run in the right straight angle.
Built the forward stools.
DaDokta attached the following image(s): Greetings, Walter
Looks good Walter Al
Looking good Walter. Neat job. Alan. Today is the tomorrow you wished for yesterday!
Thanks Al and Alan!
The beakhead main rail was next. As the main rail directly ends in the main timberhead i attached the curved part of the rail to a 4x4mm wood piece.
I also modified the foremost beakhead-frame - as there is no horizontal part on the real Vic.DaDokta attached the following image(s): Greetings, Walter
 Lovely work Walter your attention to detail is stunning Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Nice work Walter, she's looking good.
Hi Walter, Great update as always. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Nicely done Walter Al
 Looking very good walter. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi there! It´s been a while - i was on a two weeks vacation.
My next project was the completion of the bow rails.
What i wanted to achieve was the look as on the real ship, where the rails run "through" the beakhead frames.DaDokta attached the following image(s): Greetings, Walter
1.first step was to remove the lateral parts of the beakhead Frames - with that removing the preformed Slots - and being able to Position the rails in the right place. This i had done previously.
2. I attached the rails to the frames in the correct position.DaDokta attached the following image(s): Greetings, Walter
3. I prepared some 3x1mm wood strips. I tried to do the painting before attaching them - but somehow failed with the masking and it looked ugly.
4. I attached the strips over the rails - connecting the stem with the main rail.
5. The gaps between the strips and the frames were filled with wood filler, sanded and painted. DaDokta attached the following image(s): Greetings, Walter
Finally i had to redo the blue fields. This time - after masking - i applied a layer of yellow to seal the tape ( which was the step i forgot the first attempt - causing the blue paint to run under the tape). Then applied the blue colour. This time i was satisfied with the result ( still have to do the starboard side). I think i could achieve the look i had in mind with the rails running through the frames.DaDokta attached the following image(s): Greetings, Walter
Walter That looks really neat. A lot of skill putting this part of the ship together i can see but your end result is well worth the time you put in. Happy Modelling
Guest (16)
