 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
tigerace wrote:Result spike  hope the colour turns out just as you want it too  quite detailed and large  can`t wait for more  regards Phil Thanks Phil this is my first time using spray paint  so not sure how its going turn out as last time i used spray paint i put to much on in some places and in others not so much. Duane Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Finished Builds - Nissan GTR, Millennium Falcon.
Other model kit builds - Tamiya RC Trucks, Tamiya RC cars
Thanks for looking.
Duane
Got the cab painted don't look to bad saying its my first time spraying. I will get the seats and dash painted, the bash will be grey and i will do the seats tan. I will put some LEDs at the back of the dash to light up the panel and connect them to the mfu when i get it, the dash lights will come on when the head lights turn on. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
 Looking good with the paint Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I have put the first coat of paint on the seat to see how it looks and i think i will go ahead with the colour. I have also picked up a bruder figure to go inside the truck. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
arpurchase wrote: Looking good with the paint Thanks arpurchase i have got tiny hairs under the paint and there making it look a mess. I need try and sort it out maybe sand down the areas and respray. I will get a spray booth built before i do any more spraying. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Like the colour Spike, and a nice Bruder figure as well.
AL
spike wrote:arpurchase wrote: Looking good with the paint Thanks arpurchase i have got tiny hairs under the paint and there making it look a mess. I need try and sort it out maybe sand down the areas and respray. I will get a spray booth built before i do any more spraying. Try wet sanding when you sand it then just build up very light coats
Spal wrote:Like the colour Spike, and a nice Bruder figure as well.
AL Thanks Spal, i didn't think the colour would of been that good as on the pictures it looks more black then blue. The glitter mixed with the blue stands out and after a clear coat goes on the glitter will shine. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
davetwin wrote:spike wrote:arpurchase wrote: Looking good with the paint Thanks arpurchase i have got tiny hairs under the paint and there making it look a mess. I need try and sort it out maybe sand down the areas and respray. I will get a spray booth built before i do any more spraying. Try wet sanding when you sand it then just build up very light coats Thanks for the tip i will give that a try. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I will start the build and add the extras later on. The chassis has been put together apart from the servos and servo mounts. File Attachment(s): 1.jpg (278kb) downloaded 12 time(s).spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I got my RC pack this morning so i have added the servos. I have put the dampers together and fitted them to the chassis. All the leaf springs are fitted to the chassis. i will be upgrading the dampers later on. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
I put an LED strip light at the back of the dash to see how it looks. The dash has been painted and ready to go in the cab. I will sand the cab down and respray it. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
 Going together well and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Spike  like the lit up clocks. Al
arpurchase wrote: Going together well and nice work Thanks for looking arpurchase Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Spal wrote:Nice work Spike  like the lit up clocks. Al Thanks Spal i may try and light up the other dials but the plastic is a lot thicker. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fixing together the differential housings. The E rings are very tricky with them being so small. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Next the back axles and dampers are fitted to the chassis. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
The step plates go on and connect to the chassis. The the fuel tanks and tool boxes are built and added to the step plate. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
The gears and motor are put together and then placed into the gear box housing then added to the chassis with the propeller shaft. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
