106 Pages «<4950515253>»
#1001 Posted : 27 July 2017 07:56:56
Fourth and final brass strip fitted to the port side of the stern.
#1002 Posted : 27 July 2017 08:16:08
Very nice progress, looks good.....Drool Drool
#1003 Posted : 27 July 2017 08:17:15
First strip fitted to the starboard side.
#1004 Posted : 27 July 2017 08:19:02
I continued in this fashion for the remainder on the starboard side.
The attached photo shows the final strip fitted.
#1005 Posted : 27 July 2017 08:21:16
Thank you Alan. Cool BigGrin
Phil.
#1006 Posted : 27 July 2017 08:22:26
An angled shot showing all starboard strips in place.
#1007 Posted : 27 July 2017 08:23:30
Starboard side view showing the U-boat so far.
#1008 Posted : 27 July 2017 08:27:15
Moving on, the next job was to fit the rudder mount. In the photo you can see when it was dry fitted that there's a gap around the edges. Rather than fill these i opted to make a plastic spacer on the front section to aid fixing when glued.
#1009 Posted : 27 July 2017 08:28:04
This photo shows the plastic spacer fitted to rudder mount.
#1010 Posted : 27 July 2017 08:29:24
Rudder mount being test fitted with spacer.
#1011 Posted : 27 July 2017 08:34:32
Once i was happy with the fit, the next task was to drill through the body to accept a 2.0mm diameter brass rod. The rudder mount, even when glued, could be easily knocked off so pinning parts like this makes them phenomenally strong. I have used this technique throughout my build on all the major components.
The attached photo shows the hole drilled and the brass rod being test fitted to check for clearance.
#1012 Posted : 27 July 2017 08:36:03
I then withdrew the rod and fixed the mount with pva to the hull. I used clips to ensure it aligned correctly.
#1013 Posted : 27 July 2017 08:38:57
Once the pva was set after 24hrs, i back filled any gaps with superglue. From then i could confidently drill through the rest of the hull to accept the brass dowel.
The attached photo shows the mount fixed in place.
#1014 Posted : 27 July 2017 08:40:23
This photo shows the dowel being inserted to check for clearance prior to it being cut to length,
#1015 Posted : 27 July 2017 08:42:15
I glued the dowel in place and left to set. It's now very strong and robust.
Once all was dry i then filled any gaps.
#1016 Posted : 27 July 2017 08:42:53
All filler sanded smooth.
#1017 Posted : 27 July 2017 08:43:31
Rudder mount completed.
#1018 Posted : 27 July 2017 08:45:20
Well that's it for this week. More updates to follow next week.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
#1019 Posted : 27 July 2017 09:33:38
looking fantastic
#1020 Posted : 27 July 2017 09:53:38
jase wrote:
looking fantastic
Cool Thanks Jase!BigGrin
Guest (14)
This page was generated in 1.405 seconds.
