Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Issue 28 Now to secure the wheel in place. Another bearing and the wheel frame/support for the other side. Ritchie69 attached the following image(s): Completed - R2D2
Coming together nicely, great job.
Lovely progress Ritchie
Nice update Peter. It really starts to have some weight about it now. Mark Regards Markwarren (Mark) Admin
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
That's one sexy leg right there. DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
But the sexiest of legs are covered in black! [I might even be able to show you one in a couple of weeks.] Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks all. The start of the build started slow, as nothing much to do each month. Now there is more to do each month. R2 will be some weight once finished, as the left leg has still more to be added and is quite heavy already. Now have to wait for next months parts so as I can test out the projector. Peter Completed - R2D2
Joined: 05/03/2017 Posts: 531 Points: 1,710 Location: Midlands, UK
Coming along nicely. I believe the finished weight is around 8.5kg!! You can still plug the screen in to check it works, it just wont project on to a wall. Probably worth checking just to be sure. Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
semaj wrote:Coming along nicely. I believe the finished weight is around 8.5kg!! You can still plug the screen in to check it works, it just wont project on to a wall. Probably worth checking just to be sure. Cheers for the info, just checked plugged in the screen to see if it works ok and all good Peter Completed - R2D2
Finally got this months pics onto the PC Been eagerly waiting for issue 29, so I could test the projector. Issue 29 Well I wasn't disappointed with this issue. Put all parts together very carefully, so as not to get any fingerprints on the lens or disturb the wire into the screen. Once built it worked as it should Ritchie69 attached the following image(s): Completed - R2D2
Issue 30 This part doesn't loo much when there are only 2 parts in this issue, but its probably the most to be done in 1 issue so far. Added the motor for the leg, then the fun started as we then had to install the motor & foot sensor wires (making sure there is enough slack) then tie them down with the zip strips. We then put on all the leg casing and screwed it all into place. Ritchie69 attached the following image(s): Completed - R2D2
Issue 31 Only the casing of the foot to attach, so not too much. Ritchie69 attached the following image(s): Completed - R2D2
Issue 32 Only the foot sensor to attach. More screws to put away for later. Ritchie69 attached the following image(s): Completed - R2D2
Very nice progress, R2 is certainly growing now....  .. Well done... Regards Alan
Nice work, certainly taking shape now Mark Regards Markwarren (Mark) Admin
Looking good, nice work. You can start to get a feel for the final size and weight of R2.
thanks all, really enjoying the build. Completed - R2D2
That time of the month again Issue 33 Fit the base plate and put the base ring together. Then attach to the dome. The powerbus cables are for the next issue. Ritchie69 attached the following image(s): Completed - R2D2
Issue 34 We test the leg motor, then finish off the leg by adding the full cell. Ritchie69 attached the following image(s): Completed - R2D2
