Grating hatches Options
jeff averre
#1 Posted : 07 April 2011 23:29:29
Has anyone else been short changed with the length of 2x2mm strip for the hatches, I was finishing the second hatch when I ran out of 2x2, (about 1.5" short) non was wasted so I was looking for another length as there has always been spare strips for all the other jobs, looking through the 'mag' I see only one length was issued.
Not a big problem, which was sorted by plaining a wider strip to size, just a bit miffed about having to spend time to do this.
Hope it's just a 'one off'!
Jeff
saintsman123
#2 Posted : 07 April 2011 23:45:06
I seemed short of 2mm x 2mm, but had some spare wood lying around so was ok, I thought at first I had misplaced some, as I have stained mine and had put the supplied wood aside to dry.
Come on you Jimmies
Tarbrush
#3 Posted : 07 April 2011 23:51:34
Hi Jeff,
Did you not get 2 lengths of 2x2mm? Sure you haven't misplaced 1. I think there was 1 with each set of hatch parts over 2 issues. I dropped pack 45 under the bench when I was doing the deck beams and thought the worst. Found it later after the panic had subsidedBlushing
I'm sure Admin will sort you out if you are short.BigGrin
Laury
jeff averre
#4 Posted : 08 April 2011 21:25:47
No Tarbrush, as mentioned earlier I have accumulated a lot of spare strips of various sizes but not 2x2. I've been through the mags to check and only one was sent, it's now sorted but like you have stained and only noticed the shortage when assembling, only a little time wasted but I hope it's the only time 'DeAgo' miscalculates measurements!
Jeff
jeff averre
#5 Posted : 08 April 2011 21:28:12
Sorry Tarbrush, it was Bob that stained!!
Jeff
saintsman123
#6 Posted : 08 April 2011 21:38:09
Jeff
Yup, thats me, if it moves stain it, if it doesn't stain it anywayBigGrin
Come on you Jimmies
This page was generated in 0.107 seconds.
