16 Pages «<1213141516>
Eaglemoss Delorean Options
spike
#261 Posted : 21 July 2017 15:24:26
Issue 27
Parts -
Horn
Horn Bracket
2x Radiator Fans
Radiator Back
Radiator Mounting Bracket (Left)
Radiator Mounting Bracket (Right)
3x NM Screws
1x GP Screw
2x HP Screws
spike attached the following image(s):
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Finished Builds - Nissan GTR, Millennium Falcon.
Other model kit builds - Tamiya RC Trucks, Tamiya RC cars
Thanks for looking.
Duane
spike
#262 Posted : 21 July 2017 15:35:02
Place the horn bracket on top of the horn and secure with an GP screw. Place the assembly on to the front left of the chassis and add an NM screw.
Thanks for looking.
Duane
spike
#263 Posted : 21 July 2017 15:43:58
Secure the radiator mounting bracket (left) to the front left of the chassis in front of the horn with an NM screw. Do the same with the right radiator mounting bracket on the front right of the chassis.
Thanks for looking.
Duane
spike
#264 Posted : 21 July 2017 15:48:34
Place the 2 radiator fans onto the posts on the radiator back and secure with 2 HP screws.
Thanks for looking.
Duane
spike
#265 Posted : 21 July 2017 15:55:53
Issue 28
Parts -
Radiator Grille Back
Radiator Grille
Radiator Mount
6x AP Screws
4x FP Screws
Thanks for looking.
Duane
spike
#266 Posted : 21 July 2017 16:12:09
Place the radiator grille into the recess in the radiator grille back. The place the radiator mount onto of the radiator grille and secure with 2 FP screws.
Thanks for looking.
Duane
spike
#267 Posted : 21 July 2017 16:15:07
Place the radiator fans from the last issue (27) onto the back of the radiator grille and fix in place with 6 AP screws.
Thanks for looking.
Duane
spike
#268 Posted : 21 July 2017 16:17:55
Place the radiator assembly onto the brackets at the front of the chassis. Then fix in place with 2 FP screws.
Thanks for looking.
Duane
spike
#269 Posted : 21 July 2017 16:22:48
Issues 29
Parts -
Chassis Plate
Centre Plate
2x BM Screws
6x DM Screws
Thanks for looking.
Duane
spike
#270 Posted : 21 July 2017 16:40:29
Fit the chassis plate against the underneath of the chassis and secure with 2 DM screws. Then add 4 more DM screws into the holes on the chassis plate.
Thanks for looking.
Duane
spike
#271 Posted : 21 July 2017 16:43:43
Turn the chassis over and secure the centre plate with 2 BM screws (top side closest to the engine).
Thanks for looking.
Duane
spike
#272 Posted : 21 July 2017 16:45:48
Some pictures of how the car looks so far and next to the Ford Mustang.
Thanks for looking.
Duane
#273 Posted : 21 July 2017 19:20:14
Great update SpikeBigGrin good to see it alongside the Mustang for size.
spike
#274 Posted : 21 July 2017 19:44:33
Thanks for looking Spal, they are about the same size.
Thanks for looking.
Duane
spike
#275 Posted : 29 July 2017 13:59:07
Issue 30
Parts -
Left Engine Water Pipe
Right Engine Water Pipe
Left Water Rail
Right Water Rail
Lest S Pipe
Right S Pipe
Front Left Water Pipe
Front Right Water Pipe
2x AM Screws
2x JM Screws
2x AP Screws
4x FP Screws
Thanks for looking.
Duane
spike
#276 Posted : 25 September 2017 22:19:28
Insert the front left water pipe into the hole in the back of the radiator, then fix into the chassis with a JM screw.
Thanks for looking.
Duane
spike
#277 Posted : 25 September 2017 22:23:03
Secure the left water rail to the underside of the chassis with 2 FP screws. Then fix the rear end of the water rail to the inside of the chassis with a AM screw.
Thanks for looking.
Duane
spike
#278 Posted : 25 September 2017 22:26:29
Connect the left engine water pipe to the end of the left water rail and the water pump.
Thanks for looking.
Duane
spike
#279 Posted : 25 September 2017 22:30:18
Fit the left S pipe to the left water rail with an AP screw. Insert the end of the S pipe into the end of the front water pipe.
Thanks for looking.
Duane
spike
#280 Posted : 25 September 2017 22:35:11
Insert the split end of the front right water pipe into the holes in the back of the radiator and secure to the chassis with a JM screw.
Thanks for looking.
Duane
This page was generated in 2.867 seconds.
