Very impressive Spike  looks great  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Nice work on that engine Spike  looks great. Al
Looking good Spike, the engine is really starting to take shape now
 Rank: Pro  Groups: Registered
Joined: 04/07/2016 Posts: 297 Points: 897 Location: UK
Thanks guys for looking in  the engine is a nice size and loads of detailing, should look grand when its all finished. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Finished Builds - Nissan GTR, Millennium Falcon.
Other model kit builds - Tamiya RC Trucks, Tamiya RC cars
Thanks for looking.
Duane
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,063 Points: 15,335 Location: ipswich
Just a thought...
So far, all the engine/gearbox parts are the same silver colour. I haven't looked or Googled, but would a few different silvers, gun metals, black etc add more interest and visual appeal?
Having said that, I'm very tempted to start on mine...
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
roymattblack wrote:Just a thought...
Having said that, I'm very tempted to start on mine... seen a couple of good ones on facebook, it makes a difference.
Sorry guys for taking this long to update the build. Had so much on But now i can get back to working on the build i am 9 issues behind so i will get them all put on today. Issue 22 Parts - Bracket Cover Arm Throttle Control Thermostat Fuel Distributor Fuel Injectors Mixture Control Unit Mixture Unit Housing and Throttle Valve Assembly Intake Manifolds 13x AP Screws 1x MM Screw Hoses (Short) Hoses (Medium) Hoses (Long) spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Lower the cover onto the bracket then place the assembly onto the post on the front of the engine and fix in place with an MM screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fix the thermostat to the top of the engine at the rear and add 2 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the throttle control onto the arm and add an AP screw. Place the assembly onto the top of the engine and secure to the thermostat cover with an AP screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the fuel distributor onto the square part on the mixture control unit, aligning the holes on both parts, then add 2 AP screws. Add the assembly onto the mixture unit housing and add an AP screw. Take the assembly and fit the intake manifolds onto the end and secure with 2 AP screws. Place the assembly between the air intakes on top of the engine and then secure with 4 AP screws. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Insert the 6 fuel injectors into the holes in the top of the distributor facing left and right. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Fit 1 end of a short hose onto the front right injector and the other end onto the first post on the right cylinder head. Fit the second short hose between the front left injector and the first post on the left cylinder head. Fit a medium hose between the second right injector and the second post on the right cylinder head. Fit the second medium hose between the corresponding parts on the left side of the engine. Fit a long hose between the last 2 points on the right of the distributor and the cylinder head. Fit the second long hose between the same points on the left side of the engine. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Great update Spike  really look an impressive lump  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Great update Spike  really look an impressive lump  regards Phil Thanks for looking in Phil the details are fab i may go the extra mile with some more details on the engine. Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Issue 23 Parts - Distributor Bracket Distributor Rear Distributor Front Engine Side Bracket Transmission Case Left Bracket Transmission Case Right Bracket Dipstick 3x AM Screws 4x DM Screws 3x AP Screws spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the engine side bracket up against the right side of the engine add secure with 2 AM screws. Combine the Distributor front and rear and fix them together with an AP screw. Place the alternator assembly on the right side of the engine below the engine bracket and secure with 2 AP screws spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Place the distributor bracket onto the rear of the engine and the alternator and fix in place with am AM screw. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Pass the dipstick through the manifold and into the dipstick hole in the bottom of the engine. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Secure the transmission case bracket to the left side of the transmission case and add 2 DM screws. Do the same on the right side of the transmission case. spike attached the following image(s): Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Thanks for looking.
Duane
Guest (5)
