20 Pages «<34567>»
Karl's H.M.V Endevour.Part work's with Eaglemoss. Options
#81 Posted : 07 April 2011 16:47:14
the deck beams are done,danish oiled the decks,and using maple for deck covering.
#82 Posted : 15 April 2011 10:47:29
this weeks issue.
#83 Posted : 15 April 2011 10:48:35
not a lot to do this week.
#84 Posted : 21 April 2011 14:57:36
this weeks issue,adjustment to made here,on cutting the 5x2mm.piece to pack up the bow cross brace,I needed to remove it(not used,)instead I cut the 5x5mm to length and glued that as the 5x2mm was not needed.all ok after that.
the pic shows that the 5x5mm cross member is too high,so removed the 5x2 underneath.
#85 Posted : 21 April 2011 15:00:11
#86 Posted : 21 April 2011 15:02:20
covered the rear deck in walnut but NOT glued yet.
Venice
#87 Posted : 25 April 2011 23:37:17
Looking good Karl, been away for a couple of weeks so will go and pick up my parts on Thursday and will have 3 weeks worth to catch up on
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
Photobox build album
It cant be that bad, what do you mean it's sinking
#88 Posted : 13 May 2011 20:43:41
the next lot of pics will show that i've changed the decking to the planks supplied,I did'nt like the danish oil colour.
#89 Posted : 13 May 2011 21:06:41
#90 Posted : 13 May 2011 21:08:02
#91 Posted : 13 May 2011 21:09:06
#92 Posted : 19 May 2011 14:19:32
were up to issue 17 now,and deck furniture is now started,stirway has now been added.
#93 Posted : 19 May 2011 14:21:08
#94 Posted : 19 May 2011 14:23:23
#95 Posted : 19 May 2011 21:03:33
BigGrin Great job KarlBigGrin pics are great.
Cheers
benny
#96 Posted : 19 May 2011 21:19:13
hi karl the build is looking good..this is what happens to oil if its not ragged off after 30 seconds or a minute,alot of people treat it like paint and leave to dry,but oil needs to soak in and the surplus taken off with a clean cloth,but dont leave to dry before ragging
cheers benny
#97 Posted : 26 May 2011 12:43:43
issue 18 just two pieces of the forecastle bulwarks to do,slight ajusment on first piece then I glued and pinned it to deck.
#98 Posted : 26 May 2011 12:44:53
#99 Posted : 26 May 2011 12:46:06
2nd piece was ok,so just glue and pin.
#100 Posted : 26 May 2011 12:47:21
Guest (5)
20 Pages «<34567>»
This page was generated in 0.202 seconds.
