4 Pages «<234
Pocher Bugatti Type 60 Options
#61 Posted : 19 July 2017 13:51:28
Hello there Keith.
The springs were a real pain. Each leaf was very 'springy' and extremely stiff.
Not only that, but for some odd reason they varied in the springy-ness department so that it was an added difficulty getting the curve the same all the time.
I literally rolled each leaf around a piece of 40mm tube.
The curve was WAY more than required, but the parts sprung back to almost straight. After half a dozen goes at that with little effect, I resorted to using pliers, and bending each leaf at 10mm intervals whilst trying not to get a crease.
The shorter the leaf, the tougher it became.
The end result wasn't perfect, but they all fitted together fairly well.
I contemplated wrapping the springs in cord but I like the look of the leaves in the blackened steel they came as.
#62 Posted : 20 July 2017 00:23:06
Making some great progress on this Roy BigGrin never knew that the early Bugatti's had the gears fitted, you always learn something knew on this forum.
mpfiend
#63 Posted : 20 July 2017 12:00:38
roymattblack wrote:
Hello there Keith.
Thanks Roy, sounds like fun.....
Keith.
#64 Posted : 20 July 2017 15:26:04
Great update RoyBigGrin the engine looks superbDrool Drool and those springs are outstandingBigGrin regards PhilCool
michu
#65 Posted : 20 July 2017 15:46:32
I wonder if it would be possible to anneal them... basically you heat up over the flame, then leave to cool down slowly. They should become much easier to shape. Then you should be able to bring back the springiness at least to some point by heating up again and cooling them down immediately by submerging into cold water.
Happy building :-)
#66 Posted : 07 August 2017 20:30:50
Hello chaps.
Apologies for the slow updates but it is, after all, Summer - even if it isn't great.
Most evenings will find me sitting in the garden with a glass of plonk so little model-bashing is going on. Daytime, I'm playing with my 1:1 toy car...
However, the front springs, uprights and assorted gubbins are now assembled and fitted. Nothing overly complex here so not really much to say other than it's a fun build.
I'm considering putting the whole thing to bed for a few months as for me, Autumn/Winter/Spring is model time.
Roy.
#67 Posted : 07 August 2017 22:50:18
Looks good with the engine in Roy Cool
mpfiend
#68 Posted : 09 August 2017 14:50:22
Coming along very nicely Roy.
Best regards
Keith
#69 Posted : 18 August 2017 10:09:50
Very impressive. Nice work Roy.BigGrin
#70 Posted : 18 August 2017 10:34:27
looks great RoyDrool looking forward to you restarting thisBigGrin regards PhilCool
kpnuts
#71 Posted : 21 August 2017 15:50:26
More superlative work roy
#72 Posted : 22 August 2017 18:25:11
Very nice progress indeed Roy Drool
4 Pages «<234
This page was generated in 0.134 seconds.
