3 Pages <123>
Nightwisher's king tiger Options
#21 Posted : 04 July 2017 13:00:59
Cool Looking fantasticBigGrin
Ian
nightwisher
#22 Posted : 12 July 2017 23:07:30
Hi everyone,not really a fan of photo etch don't like cutting it bending it or glueing it but this is quite nice stuff.The grills are nicely rendered yet thick enough to file smooth without distorting them .The raised grills needed bending but meng provide us with a two part former where you place the etch inbetween and just squeeze together, works quite well.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#23 Posted : 12 July 2017 23:48:42
Excellent work Cool Do you know yet what colour scheme you're going with?
#24 Posted : 13 July 2017 07:48:21
They look excellently, just adds that little more depth. Great work.
#25 Posted : 13 July 2017 08:23:07
The kit etch looks great, the former is always handy, keep it for future projects!
#26 Posted : 13 July 2017 13:52:35
Looks nice and tidyBigGrin etch does add a lot to the finish thoughBigGrin excellent jobDrool ThumpUp regards PhilCool
#27 Posted : 13 July 2017 18:07:17
Very nice work indeed. I find that etch is sometimes overkill. I do use it, but I am selective on what I use as the kit part can have better detail than the etch replacing it.BigGrin
#28 Posted : 13 July 2017 18:49:36
Very nice work nightwisher, that etch bending part works a treat and is quite a nifty idea on the part of the manufacturer. Cool ThumpUp
I agree with Daran, blindly using every piece of etch just because it's on the fret isn't necessarily the best way to go, as very often you are trying to replace a 3D part a piece of 2D etch which isn't always an improvement over the kit part? Best to cherry pick the best bits of both the kit and the etch for the ultimate blend of both detail and correct scale thickness?
Keep up the good work. Cool
nightwisher
#29 Posted : 13 July 2017 19:19:52
Thanks for the encouraging comments guys,I am especially happy you armour specialists like what I'm doing. Dave I will be attempting the three colour ambush cammo scheme,a tad ambitious maybe ,considering I am still new to airbrushing.
#30 Posted : 13 July 2017 22:35:53
You're doing fine Nightwisher, and don't worry too much about the three colour camo scheme possibly being above your skill set, it won't be. One of the great things about armour modelling is that in reality most of the armour was painted in the field with whatever could be found so was never perfect, or it was covered in muck and weathering and the camo scheme couldn't be seen in any great detail anyway. If you make a mistake when airbrushing, just stop and consider whether it could easily be sprayed over or adjusted or maybe even cover it with some stowage or mud/dust and you can always touch up some slight overspray with a 'hairy stick' (brush) if needs be ? Even if your camo as sprayed doesn't match the diagram in the instructions, that doesn't mean yours is wrong as no two tanks were ever painted exactly the same, they were just vaguely similar, and that's all you need to aim for?
Hope that helps?
nightwisher
#31 Posted : 18 July 2017 23:03:37
Nice one kev ,Thanks for those encouraging words,have just ordered the paint.Had a go at the tracks the weekend ,meng provide us with a former to help get the correct sag and it works quite well .I used the wheels to form the curves of the lower run and joined them together with the longer parts .I plan on leaving the tracks in half until after painting and will proberbley leave the skirts off until the tracks are fitted.
#32 Posted : 19 July 2017 07:22:11
coming along very nicely.
#33 Posted : 19 July 2017 07:36:34
loving the track jig
nightwisher
#34 Posted : 09 August 2017 22:40:22
Back again for another update .Finished both sides of the track,very pleased with the fit ,Just wedged on with a bit of cardboard for now.Started on the turret,the parts are an excellent fit just needed a bit of filler around the front armour plate (this may have been my fault) here are a few pics.
#35 Posted : 10 August 2017 07:37:56
Coming along nicely, the tracks look spot on with the amount of sag.BigGrin
#36 Posted : 10 August 2017 07:41:57
Kit looks great, the surface texturing is good, often overdone on some kits but not on this one.
The moulded on rain guard on the gun sight looks a little thick to me I would be tempted to relplace with some thin plastic card.
great build keep the pics coming
#37 Posted : 10 August 2017 08:54:54
Nice work, tracks look excellent.
#38 Posted : 10 August 2017 13:37:10
I do like the look of these Meng kits i have two of themDrool Drool BigGrin getting tempted to start mineBlink as yours looks superb well doneDrool Love regards PhilCool
#39 Posted : 10 August 2017 18:21:44
BigGrin Looking good and those tracks look greatCool
#40 Posted : 10 August 2017 23:07:36
Looking good, really nice progress....Cool Cool
3 Pages <123>
This page was generated in 0.204 seconds.
