51 Pages «<1920212223>»
DaDokta`s Build Options
#401 Posted : 11 July 2017 12:08:04
Next step were the fenders. I wanted to make them a little bit more descreet than the instructions suggest - also i wanted no gaps to the hull.
So i had to adjust some of the wriggles that were in the way. Used 2x1mm walnut fo the finish.
As often i was like - oh well i`ll just quickly make those fenders - which then turned out to be a 4h-job!!
Who needs sleep anyway? :)
#402 Posted : 11 July 2017 15:14:34
Hi Walter,
The ladders and entrance looks fantastic.
#403 Posted : 12 July 2017 11:29:26
Hi Walter.
Cool looking fantastic. well done. Ian BigGrin
z8000783
#404 Posted : 14 July 2017 12:56:08
Groups: Unapproved
Lovely work work, Walter. Those lines are just about perfect.
#405 Posted : 17 July 2017 08:04:30
Thanks guys!
Again a small update as i completed all the fenders.
Again i deviated from the instructions regarding the front fenders and built them more straight and not running along the curve of the hull.
z8000783
#406 Posted : 17 July 2017 08:20:17
Groups: Unapproved
Yes, you're right, they should be straight. I wonder why they did it that way.
Nice work as ever.
#407 Posted : 17 July 2017 11:27:59
Hi walter.
looking very nice. well done.
Ian Cool BigGrin
#408 Posted : 17 July 2017 11:50:04
Thanks guys!
I was informed that with the start of the new forum sometimes in fall - threads with those damn photobucket-icons instead of the pics will be deleted.
So this is also a heads-up for all of you who are also hit by the PB-issue!
To prevent the deletion i edited all my former posts in this thread and uploaded the pics directly.
As you can imagine this was a pain in the ass to do - and i only re-uploaded the most important pics.
But it`s done after all - and i hope there will never occur a problem regarding the pics any more!
Also i wanted to remind you that with the link in my signature you can see all the pics i ever made of this build.
OK guys! Now for my other threads! Crying
#409 Posted : 20 July 2017 11:31:29
Hi guys!
The wood for the cap strips finally arrived - so i gave it a go.
I started with the forcastle. As mentioned before i wanted the cap-strips to follow the curve of the hull (other than in the instructions)- also i used 8x1mm strips of pear-wood, as i want to achieve a more slim look.
Wasn`t easy to bend those strips but with hot water and a soldering iron i finally succeeded!
The painting will be finished after all the cap strips are mounted.
#410 Posted : 20 July 2017 13:05:45
Lovely work Walter, all looking great....Cool Cool
#411 Posted : 21 July 2017 08:37:59
I finnished all the cap strips ( all with 8x1mm strips).
I´m especially pleased with the stern - as i could achieve the look of the orignial as i planned.
#412 Posted : 21 July 2017 09:41:14
Another very nice update Walter, looks great....Cool Cool
#413 Posted : 24 July 2017 07:04:34
Thanks Alan!
Next i used 2x1mm walnut for the moulding-strips and some pear-wood for the carvings - which i produced in different sizes.
#414 Posted : 24 July 2017 07:08:01
I also realized that the anchor supports were missing in the instructions.
So i scracht-built them.
#415 Posted : 24 July 2017 07:20:51
Loving your mods and improvments, a qulity build
#416 Posted : 25 July 2017 07:33:40
Thanks Jase!
This is what she looks like after painting the hull and the cap strips ( i taped the areas for the chainwales).
#417 Posted : 25 July 2017 11:21:23
Great looking progress Walter, very nicely done....Drool Drool
#418 Posted : 27 July 2017 07:45:35
Thanks Alan!
Next up was the beakhead bulkhead.
Because of the my modifications to the forecastle bulwarks my beakhead bulkhead was about 1 cm less high than in the instructions - so again i had to modify the parts.
Also i used 3D-printed parts for the decorations.
#419 Posted : 27 July 2017 07:59:27
Very nice, love the detail.Drool
#420 Posted : 28 July 2017 07:44:09
Thanks Mark!
I built the first gratings - used 1x1mm strips.
This page was generated in 0.334 seconds.
