106 Pages «<4546474849>»
#921 Posted : 10 July 2017 21:41:19
Looking forward.
#922 Posted : 10 July 2017 21:43:18
Looking aft showing the torpedo hatch and the cut-out t-frames around the well.
#923 Posted : 10 July 2017 21:46:57
I then proceeded to make small sections of t-frame to fit on the lower half of the hull giving the impression that the U-boat was sliced through. It also carries on the theme I used for the other compartments as mentioned in a previous thread. I glued them oversize to make them easier to handle whilst fixing before sanding smooth and flush.
#924 Posted : 10 July 2017 21:49:43
T-frames fitted before cutting and sanding.
#925 Posted : 10 July 2017 21:51:33
Filed smooth and flush to the hull.
#926 Posted : 10 July 2017 21:52:41
The remaining t-frames filed to suit.
#927 Posted : 10 July 2017 22:04:03
That concludes this update. I still have the internal bulkheads and deck to fit before the Torpedo Compartment is ready for undercoating.
I will more than likely post another update this week before returning to my regular Wednesday / Thursday next week.
Light at the end of a tunnel a last!BigGrin The Torpedo Compartment has taken many weeks to get to this stage and i'm not far off getting it to the stage of undercoating.
I want to undercoat all of the U-boat in one session so the next two to three weeks will be fitting the part-works supplied etch for the hull sides, a few running repairs, fitting the rudder mount and making a tank profile for the Aft Torpedo Loading Compartment.
When all that is done it's time for the rivets and weld lines. These will be applied last as the undercoat seals them in place and fitting them earlier in the build would of resulted in several being knocked off during handling.
Thanks for looking in and have a great week!BigGrin
#928 Posted : 11 July 2017 11:35:58
Excellent work as always Phil and is testament to your skill and patience. I think this will be a stunning model when finished - very well done on your work so far. Drool Cool ThumpUp
#929 Posted : 12 July 2017 08:16:00
Nice update - fabulous work as always!
#930 Posted : 12 July 2017 14:57:29
Thank you Kev. Your comments are very much appreciated.
#931 Posted : 12 July 2017 14:58:26
Thank you very much for your comments Walter!
Phil W.BigGrin
#932 Posted : 12 July 2017 15:18:22
Good afternoon from 'The Dockyard'.
Another post this week after which i'll be back to my regular Thursday updates.
This post continues with fitting out the Torpedo Compartment and fixing the brass strips supplied by the part-works to the bow section.
I decided to try and fit a resin AMP I bought as a set from a German supplier a couple of years ago. The part in question forms a section located on the port side of the torpedo tubes. Due to the fact that I have now fitted the inner pressure hull and t-frames, i was conscious that the diameter would change how the part located.
First job was to saw a strip from the top of the part to allow for the new hull diameter. I then recessed the top so the part would sit around the t-frames.
The attached photo shows the part with recesses. .
#933 Posted : 12 July 2017 15:19:59
This photo shows the part being test fitted.
#934 Posted : 12 July 2017 15:42:01
After much 'umming and arring'Confused it was clear that the part would not fit correctly and a new approach was required.....Confused
I then referenced some photos of U995 to see how this was configured. It turned out it wasn't fitted, having all it's valves and pipework bolted directly to the t-frames.
I decided to follow the same route meaning I now had to scratch build part of the inner hull and extend the t-frames.
First job was to install a datum edge for the new, inner hull section to sit against. I made it using 2.0mm square strip.
The attached photo shows the datum piece fixed in place.
#935 Posted : 12 July 2017 15:44:36
This photo shows the inner hull section fixed in place. I had to fit packing pieces under it in certain locations so that it would align with the existing pressure hull.
#936 Posted : 12 July 2017 15:48:17
I used the pressure hull t-frame off cuts to make the new ones. In this photo you can see the first of three t-frames fitted. I tried to match it's curve with the existing t-frame as best I could. My thinking at the time was that I could add filler to the gap and file out a curve between the two.
#937 Posted : 12 July 2017 15:49:33
All three t-frames fitted.
#938 Posted : 12 July 2017 16:04:40
I then decided to make a small box section to hide the mdf support near to the torpedo tube bulkhead.
In this photo you can see a profiled piece I made for it.
#939 Posted : 12 July 2017 16:06:25
The box section was made of three pieces. In the attached photo you can see me test fitting the profiled piece up to the other two.
#940 Posted : 12 July 2017 16:09:25
Box section completed. Regarding the t-frames and matching them to the originals, instead of using filler I simply glued a small strip of 0.25mm plastic to cover the join on each. When dry, I sanded the edges and did the same to the hull section.
Guest (10)
This page was generated in 0.631 seconds.
