106 Pages «<4445464748>»
#901 Posted : 03 July 2017 14:52:32
delboy271155 wrote:
Hope you had an enjoyable break even if the weather was a bit naff.
Good to see you back and congrats on your "Purple" medal for 1000 posts.
Cool Cool Cool
Looking forward to your next update.BigGrin
Thank you very much Del!BigGrin Thanks for looking in and your support.
#902 Posted : 10 July 2017 21:05:09
Good Evening from 'The Dockyard'.
On this part of my build log of U230 i have 'finally' managed to fit all the t-frames to the inside of the Torpedo Compartment.BigGrin
For the t-frames I used 2.0mm square strip, bent around a sweetner container to form the curve of the hull.
I used the two spacers I made in a previous thread when fitting out the Junior Rates Mess and Galley and modified them slightly by increasing their width to better suit the Torpedo Compartment. The reason the spacers were wider was to achieve an equal distance between t-frames and the mdf supports. This was achieved by gluing an extra 3.0mm strip, increasing the width of the spacers to 12.0mm from the original 9.0mm.
Before I could tackle the t-frames I first had to file and sand the edges where the inner pressure hull meets the external hull.
The attached photo shows the join between the front and rear half of the inner pressure hull being sanded.
#903 Posted : 10 July 2017 21:06:44
The leading edge was filed, filled and sanded. This photo shows the edge sanded smooth.
#904 Posted : 10 July 2017 21:08:45
I made a small, angled piece from plastic strip to continue the cut away angle. A small detail but it adds to the 'flow' of the cut-out.
This photo shows the angled piece fitted and filed to suit.
#905 Posted : 10 July 2017 21:10:44
The attached photo shows the leading edge filed smooth. It has been filed horizontal to the boat.
#906 Posted : 10 July 2017 21:12:48
First t-frame fitted. Cut slightly longer than needed so that it's own 'spring' effect will help to push it against the pressure hull when glued.
#907 Posted : 10 July 2017 21:15:23
I then glued the 4th t-frame as this one would have to align with the existing mdf support. Once fitted I calculated the required width for a further two t-frames inbetween [12.0mm].
The attached photo shows the 4th t-frame and also the 2nd t-frame in place.
#908 Posted : 10 July 2017 21:19:41
This photo shows the 2nd t-frame being cut where it crosses over the torpedo loading hatch well.
At sea, two heavy cast iron bars were fitted across the well to strengthen the hull and then removed whilst loading torpedoes.
Once I have added detail to the hatch I might retro fit two bars across it as per the real thing.
I used a slitting disc to rough out the cuts.
#909 Posted : 10 July 2017 21:22:13
This was followed by a small grinding wheel used to carefully remove the majority that was left before a final sand to ensure the cut t-frame ends aligned with the hatch well profile.
#910 Posted : 10 July 2017 21:24:08
The 2nd frame cut to shape. In this photo you can also see where I bevelled the edges of the t-frames to suit the hull and also to match the style I used on previous compartments.
#911 Posted : 10 July 2017 21:25:12
From another angle.
#912 Posted : 10 July 2017 21:26:42
This photo attached shows the 3rd t-frame being fitted.
#913 Posted : 10 July 2017 21:28:21
In this photo you can see the 3rd t-frame being aligned against the 12.0mm spacers I mentioned earlier.
#914 Posted : 10 July 2017 21:29:29
3rd t-frame fitted.
#915 Posted : 10 July 2017 21:31:34
3rd t-frame cut out to accommodate the hatch well using the same method as the 2nd t-frame.
#916 Posted : 10 July 2017 21:32:41
The attached photo shows the 2nd & 3rd t-frames cut and filed to suit the hatch well.
#917 Posted : 10 July 2017 21:34:12
I then continued to repeat the bending/cutting process for the remainder of the t-frames.
The attached photo shows all t-frames fitted.
#918 Posted : 10 July 2017 21:37:53
In this photo you see the t-frames being sanded to align them with the bevelled, leading edge.
#919 Posted : 10 July 2017 21:39:09
This photo shows the t-frames when looking aft.
#920 Posted : 10 July 2017 21:40:08
Looking at the t-frames square on.
Guest (10)
This page was generated in 0.572 seconds.
