rear of the ship HELP Options
cal
#1 Posted : 04 April 2011 22:14:09
hi everyone ive just opened issue 24 & noticed that the pic on page 11 shows the planks comming level with the galley support mine are just below it can i get away with adding a plank to it to build it up?
saintsman123
#2 Posted : 04 April 2011 22:47:32
You should be ok, as you have to do some sanding later, and the galley sides cover that bit up, but wait and see what the experts say.
Come on you Jimmies
jeff averre
#3 Posted : 04 April 2011 23:13:54
I agree with Bob, by the time you've sanded to take care of the downward curve of the gallery base there will not be much of a gap, but to be on the safe side it would'nt hurt to build the planking up a bit, there won't be any of this visible when the gallery is built!
Jeff
Wilfy the Sea Dog
#4 Posted : 05 April 2011 07:24:28
Hi,
Think you need to check your gallery supports. They should be square to the rib & keel. Yours looks as though its tipping up.
When I fitted mine I couldn't push them all the way home as this created the effect that you have.
Check out Tomicks diary.
Hope this helps.
Wilfy
cal
#5 Posted : 05 April 2011 19:33:14
thx guys all sorted now ive reseated the supports & there lower help from mr t too much appreciatedLaugh
Wilfy the Sea Dog
#6 Posted : 06 April 2011 07:18:34
Looking good cal, Glad you got it all sorted.
Wilfy
This page was generated in 0.119 seconds.
