22 Pages <1234>»
Stefan's build Options
StefanDV
#21 Posted : 04 April 2011 10:44:47
Fairing complete (I think). D@mm but that was dusty work!
The bow
Stern
Galley
First plank on!
jimbobuk05
#22 Posted : 04 April 2011 13:26:56
Its looking very good Stefan. You have shaped the stern
really well. Much cleaner than mine. I have to sort it a
bit more.
Well done. On to the planking next. !!!!
Jim
tom.ganc
#23 Posted : 04 April 2011 16:29:41
Looking good mate,
Good luck with planking, don't rush it, measure twice cut once ;)
All the best
Son of Bulwark
#24 Posted : 04 April 2011 17:59:12
Hi Stefan! Cool
So you've started, the first plank is on. Yes! the first of many! good luck mate, as Tom said "don't rush it" enjoy seeing the hull take shape, you can't beat it!
BigGrin
StefanDV
#25 Posted : 05 April 2011 11:01:26
Thanks Gents,
The sanding of the stern started to bore me so I used a mouse-sander to get it nice and flush with the false keel.
I also made part 31 out of the duplicate part 30 I received. It was a little tricky to get the curve and the spacing of the gallery supports right, but with a litte basic maths and using the 2x part 34s as templates it worked out nicely.
Once the first planks are down the rest went very quicly. The little "cutter" plankbender works very well.
Bow
Port Side
Starbord with cutaway
Stern (Starbord side)
Stern (Port side)
For some reason the planks on the Port side started rising faster than the Port side resulting in me having to trim plank nr 4 quite severly to make plank nr 5 level with the galley supports. I'll be painting the hull so I decided not to remove all the Portside planks and trim each one a little.
Thanks again for everyone's feedback, I'm really learning a tremendous amount by going through all your build dairies.
StefanDV
#26 Posted : 16 June 2011 11:34:33
On closer inspection the Gallery support planks were not wide enough, and the top of the last layer of planks needed to come up higher past the Gallery "fillets"? so I took them off and re-did that section
1st set of Gunports cut
2nd set of Gunports marked
Bow
Stern
StefanDV
#27 Posted : 16 June 2011 11:44:36
Stern gunports
And the starboard side
The last row of planks that meet at the bow rise slightly above the formers, I guess that will be sanded back at a later stage
The self-made 'dummy-gun-backing-planks' in place. You can see the little grooves on the planks where they have been cut using the supplied plank-bender
The 3rd and 4th last ribs started to bend away from one another quite severely so I have to keep them in place until all the top-planking has been completed
#28 Posted : 16 June 2011 12:37:17
Great build Stefan, very clean and methodicalLOL ThumpUp
jimbobuk05
#29 Posted : 16 June 2011 22:58:43
Your build is looking very good Stefan.
Jim
tom.ganc
#30 Posted : 17 June 2011 01:04:14
Nice planking Stefan. Don't rush it, measure twice cut once BigGrin
StefanDV
#31 Posted : 24 June 2011 10:41:59
Thanks gentlemen. Much appreciated!
As this is my first wooden model build and it is not cheap, I really want to get it right.
tom.ganc
#32 Posted : 24 June 2011 14:46:24
Good build, nice and clean. Keep it this way and you will be fine. I'm sure Cool
StefanDV
#33 Posted : 28 June 2011 13:56:07
The top-part planking is now done.
Stern
Full Starboard side
Starboard to Stern
Bow
Now I'm just waiting in nervous anticipation for the arrival of issues 32-36 to start planking the bottom.
Gerrit
#34 Posted : 28 June 2011 14:39:25
Amazing Great work!!!
Hans
#35 Posted : 28 June 2011 16:17:22
Hi Stefan
Good looking build. Following you with interest
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#36 Posted : 28 June 2011 19:01:45
Good stuff Stefan you should be proud of yourselfBigGrin ThumpUp
tom.ganc
#37 Posted : 28 June 2011 19:06:38
So far so good. Great job. I bet you can't wait to get started with lower hull BigGrin
Be careful while doing it because each wrongly shaped plank there wil be real pain later on. Keep it easy and as everyone will tell you measure twice and cut once.
Great job
jonny7england
#38 Posted : 28 June 2011 19:18:05
Coming along well mate...nice build...ThumpUp
StefanDV
#39 Posted : 29 June 2011 12:12:01
Thanks so much gentlemen!
The next order was dispatched today so hopefully it will be in my grubby paws within the next 2 weeks BigGrin
I learnt my lesson on the galley support planks where 'good-enough' did not turn out that way and had to be redone.
From following all your build dairies, I'm going to be extra careful to start of right and not allow any clinkering.
Atholm
#40 Posted : 30 June 2011 17:27:04
Nice build keep it up. The planking the lower pat of the hull I found more difficult and requires more work.
You will have to be carefull that you do not damage the top layers of the planking while doing the lower hull.
Happy building
Athol
22 Pages <1234>»
This page was generated in 0.169 seconds.
