Cross section missing pieces Options
michael.rolph
#1 Posted : 29 June 2017 22:04:40
I've just found out I am missing the two pieces of the elm tree pump from issue 135. I have contacted CS about replacement parts but due the the kit being out of stock I don't know if I will be able to get the pieces.
Can anyone provide me with the sizes of the parts (length, diameter etc.) so I make replacements if necessary?
#2 Posted : 29 June 2017 22:36:52
Hi Micheal.
I can't give you the sizes if the missing parts but If you get some square stock at a length of 152mm x 3.5mm and chamfer the corners to make it the correct shape then it will be correct height.
The other pump is 91mm high. if you cut them slightly longer then when fitted you can trim the length to be flush with the deck.
Chris.
michael.rolph
#3 Posted : 02 July 2017 21:12:14
Thanks Chris. CS has said they will send out replacements so hopefully I won't need to build my own
