 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
next we connect the lever for the push rod which lifts the ramp. stevegbr attached the following image(s):
put together the next two parts. stevegbr attached the following image(s):
now to connect the two pipes. stevegbr attached the following image(s):
slide the rack on to the ramp. stevegbr attached the following image(s):
now to assemble the next pod vehicle. stevegbr attached the following image(s):
connect these two parts. stevegbr attached the following image(s):
now connect the two together. stevegbr attached the following image(s):
turn it back over and connect the two blowers. stevegbr attached the following image(s):
connect the front to the rear. stevegbr attached the following image(s):
put the figure in the vehicle. stevegbr attached the following image(s):
now back to the pod. stevegbr attached the following image(s):
now to place the ramp for thunderbird 2, there are two recesses for the ramp. stevegbr attached the following image(s):
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
Looks great. So much detail even on the tinyest part. DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
here is issue 68. stevegbr attached the following image(s):
here are the parts for this build. stevegbr attached the following image(s):
three parts assembled in the rockets. stevegbr attached the following image(s):
this is alans racing car. stevegbr attached the following image(s):
connecting the wheels and axles. stevegbr attached the following image(s):
