applying glue to planks or ribs Options
ronald305
#1 Posted : 27 June 2017 21:49:36
Hi guys
I have a simple question what is a good method of applying glue for gluing the planks to the side of the ships for stages 21-25 and on with out making a mess , I have been using a artist paint brush at this point but do not like the mess I'm making, can I use a smaller paint brush or a glue syringe that narrows to a small hole what are you'll thoughts on this thank you
Ronald
#2 Posted : 27 June 2017 21:54:54
Hi Ron, I simply use a small brush to apply the glue and once the parts are fitted together I use a damp cloth or sponge to wipe away the excess.. works for me....Cool Cool
ronald305
#3 Posted : 28 June 2017 12:05:56
thanks Alan
Ronald
darkwoodster
#4 Posted : 30 June 2017 22:50:24
Rank: Amateur level 2
I put my glue on straight from the bottle. Creating a thin and consistent bead leaves a neat finish. Just my way.
#5 Posted : 01 July 2017 10:20:51
I use a cocktail stick. decant some glue into a milk bottle top and use the cocktail stick to apply. a damp j cloth works well for any glue seepage
Ronjamino
#6 Posted : 05 July 2017 02:26:44
I've been doing something similar to what Jase describes, but using a pointy 'thing' that came with a craft knife set. essentially looks like a metal cocktail stick with a handle :-)
I'll squeeze a bit of wood glue into a bottle cap, then just 'lift' a bit out and spread it onto the surface to be glued. basically imitating the official diary build videos. I find it to be incredibly accurate, but does sometimes need a top up to make sure a contact is made.
Good luck with the build though Ron, have you got any pictures up yet?
HMS Victory : Diary | Gallery
