First tank load Options
Steve279021
#1 Posted : 24 June 2017 18:50:56
Looks like i will be about to start it up next month. What fuel should i use for the first tank?
Dodge charger build complete
#2 Posted : 24 June 2017 19:05:16
Nothing less or more than 15% for the first 3-4 tanks and no more than 20% thereafter if you want engine longevity, the make does not matter.
Also get a bottle of afterrun oil.
Always empty the tank and fuel lines after the days running and use the afterun to protect the internals. Remember that nitro fuel is hygroscopic (absorbs moisture), thus can induce corrosion if you don't use afterun oil.
Steve279021
#3 Posted : 24 June 2017 19:48:18
I can't seem to find any 15%. Can only find 16%. Is that ok?
#4 Posted : 24 June 2017 20:41:55
Sure it's fine
