24 Pages «<56789>»
L'Hermione Build Options
RogerThornhill
#121 Posted : 15 June 2017 04:31:35
Looks fantastic!
#122 Posted : 15 June 2017 09:06:18
Thanks for all the comments guys, appreciated...Cool Cool
PiperMat
#123 Posted : 17 June 2017 17:02:23
Rank: Newbie
Hello Alan,
Very nice work! I'm currently building L'Hermione myself. I'm at the stage where the gun ports are marked out, but I think I marked them too low. Could you maybe tell me how high the bottom of the ports are in relation with the lower deck measured from the inside?
greetings,
Mathias.
nightwisher
#124 Posted : 17 June 2017 18:41:30
Nice work as usual, the bow looks quite tricky to plank being a tighter curve.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#125 Posted : 17 June 2017 18:54:43
PiperMat wrote:
Hello Alan,
greetings,
Mathias.
Hi Mathias, thanks for looking in and commenting, great to hear you building this one and hope you're enjoying it.... As for the bottom edge of the ports, I'm looking at 5.5mm from the deck, measuring from the inside.....Cool Cool .. Hope this helps..
#126 Posted : 17 June 2017 18:59:30
Hi Nightwisher, thank for looking in and commenting, appreciated....Cool Cool .. Building this in accordance with the instructions does show the bow to be a little tricky and the method used leaves the bow with a clinker effect. This will be fine after the filling and sanding phase for a painted hull but not for a natural or stained finish... Cool Cool .. Other than that the build has been pretty straight forward so far....Cool Cool Cool
#127 Posted : 17 June 2017 23:06:29
The next part of the build was to fit the garboard plank and start planking from there. The garboard plank will require a 90 degree twist to be applied both at the bow and the stern. The best way to apply the twist is to soak the plank first, fit temporarily and leave to dry in situ. Once dried then it can be glued in place leaving the planks overhanging all along the keel and at the stern and bow, I fitted a 2mm thick offcut at the stern to act as a guide.
Once the glue had dried another 4 rows of planks were added on each side. Again leaving the planks to overhang at the bow and stern and soaking the planks first to apply the necessary twists. No tapering is done on any of these rows and the stern planks need to be fanned out leaving gaps between the planks as stated within the instructions. When everything was dry the overhanging planks at the bow and stern were trimmed back, leaving an overhang of 2mm all round.
Next part soon, happy modelling...
#128 Posted : 18 June 2017 01:34:36
That`s some serious plank bending going on there, especially those Garboard planks. Great result. Cool Cool
Time and plenty of patience seems the order.
Will look in again soon, keep up the good work.BigGrin
#129 Posted : 18 June 2017 07:50:02
BigGrin Very nice workCool
Foz
#130 Posted : 18 June 2017 08:23:39
Ver nice neat work Alan, look forward to seeing your progress
Foz BigGrin BigGrin
#131 Posted : 18 June 2017 08:35:32
Very nice Alan, I'm watching and learning. BigGrin
#132 Posted : 20 June 2017 11:50:56
Hi Alan.
Looking fantastic. great update. Ian Cool BigGrin Drool
#133 Posted : 21 June 2017 08:03:54
Nice planking, Alan! Top work as always!
#134 Posted : 21 June 2017 11:42:13
Great update Alan and excellent work as always.
#135 Posted : 21 June 2017 15:09:54
#136 Posted : 26 June 2017 09:42:33
Hi Alan,
Really nice job on the planking.
PiperMat
#137 Posted : 10 July 2017 20:53:48
Rank: Newbie
Very nice planking, indeed! Tnx for the reply concerning the port holes.
I'm at the stage where the planks need to be tapered at the bow and stern. Where did you start tapering them? It's not really clear from the build manual. I'm also wondering if you sanded the top of the planks to change the inside angle?
#138 Posted : 10 July 2017 23:21:17
Hi PiperMat, I'll come back to you one this one very soon.....Cool Cool
kpnuts
#139 Posted : 17 July 2017 22:28:18
Another great build. Great stuff.
#140 Posted : 08 August 2017 06:51:27
Really coming along Alan BigGrin great work Drool regards PhilCool
24 Pages «<56789>»
This page was generated in 0.217 seconds.
