packing out ribs Options
cal
#1 Posted : 30 March 2011 19:51:45
hi everyone
has any one else had problems with ribs 14, 13 & 11 on the right hand side of the ship i seem to having to pack out the ribs quite a bit, im just putting on the 6th layer of planking ive not over sanded them, i did have problems with 15 like a lot of people have but thanks to starting very late (ok not quite true i cocked up the 1st time & had to reorder) ive read a lot of stuff on here that has been a fantastic help
benny
#2 Posted : 30 March 2011 20:00:30
hi cal 15 was my only problem..are those ribs seated properly and square
cheers benny
jimbobuk05
#3 Posted : 30 March 2011 23:15:57
Hi Cal,
I also had a problem with rib 14 on the right hand side.
I ended up having to part cut the rib and re-glue, to get
it to flow with the other ribs.
So i had to alter both 14 and 15 on the right hand side.
Looks okay now though.
Jim
cal
#4 Posted : 01 April 2011 21:50:11
im ready to start maring & cutting out the gun ports am i better of waiting until later in the build before i sand it down or do i it a bit at a time, theres a few planks mainly at the front that are a little bit wavey
StefanDV
#5 Posted : 02 April 2011 08:33:01
On the subject. Do you pack out the ribs to meet the decks or sand back the decks to meet the ribs?
#6 Posted : 02 April 2011 09:57:57
hi stefan,when I put the decks in I had to sand a little off the deck straight edge,that made the deck correct with the formers,and only needed a few minor adjustments.
willie
#7 Posted : 02 April 2011 10:04:17
sand the deck back to the ribs but check it with the other ribs first some ribs may need packing out check it with a plank across the frames and when sanding the ribs,common falts are rib 15 and may be some aft around rib 25
StefanDV
#8 Posted : 02 April 2011 12:46:41
Thanks Gentlemen!
Received my next set of issues this morning, but am still waiting for part 31 before fairing can be completed and planking started in earnest.
This page was generated in 0.103 seconds.
