packing out ribs Options
cal
#1 Posted : 30 March 2011 19:51:45
hi everyone
has any one else had problems with ribs 14, 13 & 11 on the right hand side of the ship i seem to having to pack out the ribs quite a bit, im just putting on the 6th layer of planking ive not over sanded them, i did have problems with 15 like a lot of people have but thanks to starting very late (ok not quite true i cocked up the 1st time & had to reorder) ive read a lot of stuff on here that has been a fantastic help
benny
#2 Posted : 30 March 2011 20:00:30
hi cal 15 was my only problem..are those ribs seated properly and square
cheers benny
jimbobuk05
#3 Posted : 30 March 2011 23:15:57
Hi Cal,
I also had a problem with rib 14 on the right hand side.
I ended up having to part cut the rib and re-glue, to get
it to flow with the other ribs.
So i had to alter both 14 and 15 on the right hand side.
Looks okay now though.
Jim
cal
#4 Posted : 01 April 2011 21:50:11
im ready to start maring & cutting out the gun ports am i better of waiting until later in the build before i sand it down or do i it a bit at a time, theres a few planks mainly at the front that are a little bit wavey
StefanDV
#5 Posted : 02 April 2011 08:33:01
On the subject. Do you pack out the ribs to meet the decks or sand back the decks to meet the ribs?
#6 Posted : 02 April 2011 09:57:57
hi stefan,when I put the decks in I had to sand a little off the deck straight edge,that made the deck correct with the formers,and only needed a few minor adjustments.
willie
#7 Posted : 02 April 2011 10:04:17
sand the deck back to the ribs but check it with the other ribs first some ribs may need packing out check it with a plank across the frames and when sanding the ribs,common falts are rib 15 and may be some aft around rib 25
StefanDV
#8 Posted : 02 April 2011 12:46:41
Thanks Gentlemen!
Received my next set of issues this morning, but am still waiting for part 31 before fairing can be completed and planking started in earnest.
