106 Pages «<3940414243>»
#801 Posted : 08 June 2017 21:58:28
A close up showing the supports.
#802 Posted : 08 June 2017 21:59:22
Looking from above.
#803 Posted : 08 June 2017 22:01:42
Looking from above.
#804 Posted : 08 June 2017 22:03:44
I then continued in the same fashion to make the other three torpedo tubes. This photo shows all four test fitted.
#805 Posted : 08 June 2017 22:05:30
Looking from the front.
#806 Posted : 08 June 2017 22:06:28
Another photo showing all four torpedo tubes test fitted.
#807 Posted : 08 June 2017 22:08:41
Once I was happy with the test fit of the torpedo tubes I could then permanently fix the torpedo tube bulkhead into the U-boat.
This photo shows the completed bulkhead in it's correct location.
#808 Posted : 08 June 2017 22:09:45
Another photo showing the bulkhead from distance.
#809 Posted : 08 June 2017 22:12:15
Well that's it for this week's update. Next week i'll be looking at fitting the aft torpedo compartment bulkhead and water tight door.
Thanks for looking in, have a great weekend and happy modelling.
Kind Regards,
Phil W.BigGrin
#810 Posted : 08 June 2017 23:47:30
All looking good Phil, again very nice work....Drool Drool .. She's really progressing now....Cool Cool
#811 Posted : 09 June 2017 05:18:15
Phil
Looking brilliant as ever.
Torpedo room for this model is a must have so its incredible that it was not added in the kit.
It looks really good what you have put together so far.
#812 Posted : 09 June 2017 13:04:56
Great update PhilBigGrin i`ve done something similar with my torpedo room bulkhead aswellBigGrin regards PhilCool
#813 Posted : 09 June 2017 14:10:24
Thanks Alan. Yes, making progress and a month to go until I start painting the hull!BigGrin
#814 Posted : 09 June 2017 14:15:52
birdaj2 wrote:
Phil
Hi Tony,
Yes it's a shame the torpedo compartment wasn't factored into the part-works. I bought the AMP's from Germany in May 2015. While I was waiting for my second order to arrive, [I couldn't justify spending the full amount in one go], I discovered the guy had closed down his site and shut up shop. Fortunately he honoured all orders that had already been paid including mine, so I managed to get the parts through in the end.
Thanks for looking in.
#815 Posted : 09 June 2017 20:52:04
BigGrin Nicely done on the tubesCool
#816 Posted : 12 June 2017 09:18:42
Thanks for looking in Phil!BigGrin Great minds think alike.Cool
#817 Posted : 12 June 2017 09:20:12
Thanks Andy!BigGrin
#818 Posted : 13 June 2017 10:50:54
Incredible build!
#819 Posted : 13 June 2017 14:39:15
DaDokta wrote:
Incredible build!
Thank you Walter! Your comments are much appreciated!
#820 Posted : 15 June 2017 17:58:32
Good Evening from 'The Dockyard'.
This weeks update of my U230 U-boat build will be looking at scratch building the Torpedo Compartment aft bulkhead. Having already bought this part as an AMP from a German supplier, I thought I could just file and fit. Turns out that the overall shape didn't fit correctly due to the newly curved deck head I installed a couple of weeks ago.
I started by cutting out the shape on 0.5mm thick plastic sheet and finished it off with trimming and filing until it fitted correctly. I then marked out where the bulkhead door opening would be and removed that section. Once I was happy with the profile I glued a further 0.5mm sheet to the back to aid strength.
The attached photo shows the aft bulkhead as a single sheet with the bulkhead door opening removed. Next to it you can see the brass bulkhead door that I removed from the Engine Room a few months ago to use as a template.
This page was generated in 0.411 seconds.
