Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
Ian23 wrote:Hi Roy
Yes the seat back is padded and made of the same leather as the seat cushion It looks to me like the leather on the seat back gets covered by the plastic of the support. I presume this is correct, but must admit, I hoped that the back of the seat would be leather showing. (Admittedly, I don't know what the real car was like, nor do I know if there is a further part to come that will cover this.) Can anyone please enlighten me? Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 15/03/2017 Posts: 91 Points: 276 Location: Worcester, UK
New month new parts this time we start on the engine Build the Jaguar E-Type, Part 10Parts with Issue 10Manifold Assembly (upper half) Throttle linkage Shaft Suction Chambers x3 Take the throttle linkage and the shaft and feed the shaft through the 2 small holes in the throttle linkage (picture 2) Take the shaft and align it with the manifold assembly with the 3 holes at the top of the branching points and secure with 2 screws (picture 3) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Built: Deagostini Millennium Falcon
Build the Jaguar E-type, Part 11Parts with Issue 11Manifold assembly (lower half) Petrol feed pipe Air balance pipe Air cleaner Take the assembly from stage 2 and fit it over the lower half of the manifold assembly. Press the 2 parts together and secure with 2 screws in the plenum chamber (picture 2) Next take the 3 suction chambers from issue 10 and fit them into the matching holes on the top of the carburettors. Secure each with a screw (picture 3) next take the petrol feed pipe and align the 3 holes with the 3 pegs in the assembly (picture 4) next take the air balance pipe and ensuring the alignment is correct place it in the 3 holes on top of the manifold. secure from beneath with 3 screws (picture 5) Finally take the air cleaner and making sure the label on it faces out away from the rest of the assembly push it firmly onto the 2 pegs in the plenum chamber (picture 6) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Ian Very nice update on your build. Happy Modelling
Nice update Ian, looking good Mark Regards Markwarren (Mark) Admin
Build the Jaguar E-Type, part 12Parts with Issue 12Engine block and clutch bellhousing (right side) Starter Motor Distributor This issue gives you the option to paint the engine block black and gold to more accurately match the original. I have decided against doing this for several reasons. it wont be very visible and the people I will show it too wouldn't know the difference anyway and I'm scared I will make a mess of it. So, first take the starter motor and push it into the hole behind the clutch bellhousing. secure from beneath with a single screw. (picture 2) next take the distributor and push it into the hole at the indicated and secure from beneath with a single screw (picture 3) Next take the carburettor assembly from the previous 2 issues and, making sure the alignment is correct, push the 2 lugs in the assembly into the corresponding 3 holes at the top of the engine block. secure with 3 screws. (picture 4) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Part 13Parts with issue 13Engine block with clutch housing (left side) filter head and hose Battery box Again we have the option to pain the other half of the engine but again I'm not going too. Take the assembly from issue 12 and the Filter head from this issue and push it into the indicated hole. Secure from behind with a single screw. (picture 2) Take the battery box and the other half of the engine block and fit the battery box into position as shown. secure with a single screw (picture 3) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
and with that another month comes to an end. I'm liking the look of the engine, Not as detailed as the delorean one admittedly but that's a monster! nice to see that some of the electrics are going in already as well. Will have to see if i have any A23 batteries lying around Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Another month another set of parts. And a cap this time Build the Jaguar E-Type, Issue 14Parts With Issue 14Engine Breather Ignition coil (2 parts) Ignition Lead Dynamo Dynamo end cap Timing Chain Cover Pully Fan belt and Pulleys First fit the thicker end of the Ignition lead into the notch at one end of half of the ignition coil. Fit the other half of the Coil trapping the lead between the parts. Fix the 2 halves of the coil together with a single screw (Picture 2) Fix the Ignition coil to the Cylinder head assembly from stage 2 (Picture 3) Fit the engine breather into the other 2 holes in the Cylinder head and fix from beneath with a single screw (Picture 4) Next take the Fan belt and pulleys and align them with the timing chain cover. Fix from behind with a single screw (Picture 5) Take the dynamo and fit it to the correct keyhole shaped hole in the timing belt cover and fix inside with a single screw. Align the cap and push firmly onto the dynamo. (Picture 6) Take the large pulley and line it up with the correct position on the pulley assembly and fix with a single screw. Drive a collared screw into the timing chain cover (Picture 7) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Part 15Parts with Issue 15Plug leads Forward exhaust manifold Rear exhaust manifold Rev counter generator connector Take the exhaust manifolds and attach them to the left side of the engine. Secure each with a single screw. (Picture 2) Use tweezers to fit the rev counter into the hole in the exhaust cam cover. This is a tiny piece and alot of care should be taken (Picture 3) Take the Cylinder head assembly and align it with the left side of the engine block. secure them with 3 screws. Push the lead from the battery box between the 2 posts and make sure the free end protrudes through the notch at the end. (Picture 4) Take the pulley assembly and align it with the front of the engine block. Hold it in place and align the 2 halves of the engine block. secure with 3 screws (Picture 5) Next take the ignition lead and push it into the central hole in the distributor. Next take the plug leads and push the cluster of connections into the remaining holes in the distributor. (Picture 6) Take the rest of the plug leads over the top of the engine and fit the ^ plugs into the holes in the Cylinder head (Picture 7) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Part 16Parts with Issue 16Passenger door Door handle Match the door handle to 2 holes in the outside of the door. Secure from behind with a single screw (Picture 2) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Part 17Parts with Issue 17Passenger door window Hinge Hinge retainer Take the door window and align it with the door assembly. Secure with 3 screws. (Picture 2) Align the hinge and the hinge retainer. secure with a single screw (Picture 3) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
well another month down and we have a complete engine block. the passenger door appears to be exactly the same in construction to the drivers door. Looking ahead it looks like we start on the sub frame next month with will be good. Can't wait for it to actually start looking like a car Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Looking good Ian, waiting for the next set of parts is the hardest part of the build Al
Hi Al, Yes it is. It always is! I always get to the end of the months issues and just wish I had more to do! Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Another month and whilst not as much to do this month it's all moving along. Build the Jaguar E-Type, Part 18Parts with Issue 18Passenger door trim surround Passenger door trim panel Passenger door handle Passenger window regulator handle Chrome finisher (upper) Chrome finisher (lower) Arm rest Take the door assembly from issue 17 and the door trim surround. Push them together and secure with 4 screws (picture 2) Take the door trim panel and the arm rest, Noting the arm rest orientation fasten together with 2 screws (picture 3) Take the door handle and the window winder and, ensuing they are in the correct place and orientated correctly, secure each with a single screw from behind (picture 4) Take the trim panel and push it into the door assembly (picture 5) Take the trim sections and push them into the slots in the door interior (picture 6) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, part 19Parts with issue 19Right hand inner side member Nothing to do with this issue so just keep the part ready for the next issue Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Part 20Parts with Issue 20Right upper wishbone Right lower wishbone Right suspension upright Take the inner side member from issue 19 and align the 2 wishbones as shown. Take the suspension upright and fit it over the 2 pivot points on the wishbones and secure it too the side member with 2 screws. (picture 2) Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Build the Jaguar E-Type, Part 21Parts with issue 21Left hand side member (inner frame) Again nothing to do in this issue so just keep the part too one side ready for the next issue Ian23 attached the following image(s): Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
well another month down and we have started on the internal frame work. Next month should be good with the framework getting completed Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
