Stage 45: planking the deck Options
darkwoodster
#1 Posted : 07 June 2017 12:09:02
Rank: Amateur level 2
Hello again,
I'm just wanting to check I am doing stage 45 correctly. I'm just fitting the deck beams and it seams we are not supplied with enough 1.5 x 6mm wood to cover them all. There are 5 supplied which will cover 10 frames (you get 2 out of each strip)
That makes 2 strips short for the rest of the 4 frames.
With this stage we are also supplied with 2 1.5 x 8mm strips. These would work fine with them been the correct thickness. But I can't see if they are required later in the build.
I can't use any other of my leftover wood because it's all the wrong thickness.
Any suggestions?
Any help is appreciated ;-)
Neil
z8000783
#2 Posted : 07 June 2017 12:33:45
Groups: Unapproved
You should have also received 5 plank of 1.5 x 6mm in issue 44.
darkwoodster
#3 Posted : 07 June 2017 14:05:28
Thank you John. You've stopped me scratching my head. Back on with my build..
This page was generated in 0.097 seconds.
