plannking iron Options
ronald305
#1 Posted : 06 June 2017 01:44:31
hello there
does anyone know how to us the planking iron and the 4 wood curves that comes with it, and how to keep them steady in order to the iron also how long to soak the planks before bending thank you
Ronald
#2 Posted : 06 June 2017 08:04:49
Hi Ron
You may find this link useful.
https://www.youtube.com/watch?v=O8CoV8fkYTI
I soak the planks for around 10 mins in hot water and it tends to be sufficient in most cases, sometimes I will soak for longer depending on how tight a curve I need.
To keep the profiling block steady place the block in a vice...
Hope this helps..
ronald305
#3 Posted : 06 June 2017 19:12:20
yes I should thanks Alan
Ronnie
ronald305
#4 Posted : 06 June 2017 21:39:41
sorry I meant that should work thanks Alan
Ronald
ronald305
#5 Posted : 09 June 2017 21:28:11
Hi Alan
I watched the video is ok and interesting but it would have been much better if
the video had sound or the man explaining his method
Ronald
