 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
hello there does anyone know how to us the planking iron and the 4 wood curves that comes with it, and how to keep them steady in order to the iron also how long to soak the planks before bending thank you Ronald
Hi Ron You may find this link useful. https://www.youtube.com/watch?v=O8CoV8fkYTI
I soak the planks for around 10 mins in hot water and it tends to be sufficient in most cases, sometimes I will soak for longer depending on how tight a curve I need. To keep the profiling block steady place the block in a vice... Hope this helps.. Regards Alan
yes I should thanks Alan Ronnie
sorry I meant that should work thanks Alan Ronald
Hi Alan I watched the video is ok and interesting but it would have been much better if the video had sound or the man explaining his method Ronald
