8 Pages «<45678>
Pocher Ducati - another one... Options
#101 Posted : 03 June 2017 10:54:39
Many thanks all you guys.
I haven't done a great deal on the big Duc lately - busy with other stuff.
However, front end just about sorted.
Brake calipers painted - tiny brush and strong magnifying lamp/lens.
Added the missing brake sensor cable.
The front mudguard was a tight fit but went on eventually.
Forks now permanently fixed and the suspension works a treat.
This thing is now becoming awkward to handle and work on due to the shape. At least a car tends to just sit flat...
Rear suspension next, plus some weathering to the front wheel area.
Roy.
#102 Posted : 03 June 2017 18:11:13
Hi this is looking great.luv all the mods your doing to this.cheers mick. BigGrin
#103 Posted : 03 June 2017 23:25:53
Looks fab Roy, very nice work....Cool Cool
#104 Posted : 04 June 2017 00:17:23
Looking great Roy Cool
#105 Posted : 04 June 2017 14:26:04
Really looks great Roy BigGrin it looks quite a handfullBlink did you wet and dry the front tyre to make it look used ?Confused regards PhilCool
#106 Posted : 04 June 2017 15:41:47
Hi Phil.
Yes, LOTS of sanding to both tyres as they are quite glossy OOB, and they also have a huge moulding seam around the centre.
It's quite a monster now and is becoming difficult to work on...
Great fun though.
Roy.
kpnuts
#107 Posted : 04 June 2017 20:39:47
Superb roy
#108 Posted : 04 June 2017 21:36:08
Righty-ho lads.
One extreme to the other...
Over the past 2 weeks I've done little on the big Duc.
Yesterday and today - another story.
The rear frame, wheel, brakes - all sorted.
There were a few cables etc I had to scratch but of all things, the decals on the rear wheel were a NIGHTMARE...
9 different decals all around the centre of the wheel and even the biggest was about 2mm x 0.5mm.
Lots of deep breaths, gentle tweezers and knife blade and plenty of Pinot...
The actual chain is amazing, and not difficult to fit. Tensioning it is a tad more challenging.
Brake sensor and wires had to be scratched - missing from the kit - and the centre hub had to be altered from 6 horrible black screws to 6 nuts and studs - all scratch made.
The rear assembly has been fitted and now it looks like a bike!!!
It sits on the stand (part of the kit) and is ready for LOTS more work, scratch wiring, and detailing.
Sadly, the light weathering I've added all over the place doesn't show in the pics other than the LONG time spent sanding down the tyre treads...
Roy.
Metal Mech
#109 Posted : 04 June 2017 22:33:40
Even though you always know it's a big kit, it always sill comes out shocking how truly big these things turn out. It's an amazing looking beast.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
#110 Posted : 04 June 2017 22:41:26
If you look at the last pic, you can see the front wheel is overhanging the edge of my cutting mat quite a bit - yet the rear tyre is beyond 500mm.....
This thing is BIG...
#111 Posted : 04 June 2017 23:07:39
Lovely build, wow that's big. Excellent work.Love
#112 Posted : 05 June 2017 14:00:30
That is so impressive !!BigGrin
#113 Posted : 06 June 2017 09:30:29
Excellent build Roy. If Ducati made mini moto's then this would be it! Imagine riding around on that?
#114 Posted : 06 June 2017 18:39:07
Many thanks chaps.
I must admit I'm finding this build to be great fun.
I've built up the rear suspension, kick stand and all the assorted gubbins that goes with it, and fitted it to the bike.
This behemoth is now seriously heavy and needs to be on the stand from now on - too many 'breakable' bits on the sides to lay it down.
I've also built the main upper frame and rear lights etc.
Also now fitted are the first of the actual body panels.
There are constantly new wires and leads etc being scratch made as the actual kit really has very little in this respect and there's TONS of it on the real bike.
Moving on to the front end next...
Roy.
Zero9
#115 Posted : 09 June 2017 08:02:09
This is really moving on now Roy.
Interesting to note that you are not following the kit assembly sequence.
It makes sense to get it on it's wheels for stability and ease of further work.
Dennis
#116 Posted : 09 June 2017 16:07:48
Hello Dennis.
Yes, I'm not following the instructions that come with the kit - AT ALL...
In fact, they are under a pile of bits beside my desk.
I'm using the P Koo DVD which is superb.
Paul has built the kit and knows the pitfalls. He clearly explains a 'better' way to build the model and avoid the aggro.
I am adding a mountain of extra details - something I said I wouldn't do at the outset of this build.
I've also added a lot of light weathering but it doesn't show very well in the pics.
I want the bike to look used, but kept very clean which I imagine, these 'superbikes' are.
The handlebar section is amazing.
Of the entire model, I think this section/area is without doubt one of Pocher's triumphs.
Every part is assembled exactly like the real bike - I am using the scale hardware though.
The detail and realism of these parts is unbelievable.
Ok, I'm adding the missing cables etc, but it's still stunning.
The decals are a hair-tearing exercise though.
On the left-hand control block alone there are 11 separate miniscule decals...
Lots of Pinot consumed there...
Amazing fun.
I'm NO biker but after this, I might be tempted by one of DeAgs 'full kits'...
Roy.
Metal Mech
#117 Posted : 09 June 2017 23:31:25
Wow, how close are you to being done? Looks like here isn't much left.
michu
#118 Posted : 10 June 2017 04:44:23
Awesome build!
Are you planning to repaint all the cowlings?
Happy building :-)
#119 Posted : 10 June 2017 10:15:41
Hello chaps.
Thanks for the kind words.
Surprisingly, there's still a lot to do although it looks almost finished.
I'm not going to repaint the body panels as I like the colour and they are pre-painted exceptionally well. It isn't just bare red plastic.
Before long I'll need to get a display case for the beastie but goodness knows where it's going to go as my hidey-hole is already crammed to the edges with models.
Roy.
Zero9
#120 Posted : 10 June 2017 12:35:25
Speedy Gonzales has nothing on you mate...simply whizzing along BigGrin
Dennis
8 Pages «<45678>
This page was generated in 0.235 seconds.
