3 Pages <123>
MS-06R-1A Zaku II speed build Options
#21 Posted : 30 May 2017 15:18:11
Metal Mech wrote:
[quote=darbyvet]Looking great Joel,
I didnt realize there were so many parts to the Gundam kits.I know there are different classes of models.Which class is this one?
The largest American retailer of Gundam kits is actually located in Palisades Park NY. Me and a few friends are planning a road trip there later this year. I will let you know when we plan to go and you can meet us there if you like. It totally worth seeing even if you don't buy anything.
I was on the Palisades parkway yesterday on my way home from Long Island.It is about a 5 hour drive from my home!!
Nytetrain
#22 Posted : 30 May 2017 22:10:07
OK it is a Gundam Ez8 Master grade.
Best Regards,
Ron
In the Stash: Losing count...
Metal Mech
#23 Posted: : 30 May 2017 22:50:43
Ah yes iI have one of those. Not a bad kit for a first one. It's an older MG and a bit simpler then the new ones but still fun. Comes from my all time favorite Gundam series. That's one that I am only partly painting. I decided to make the blue a brighter color and match the other two gundams from the series that I have. Can't wait to see how you tackle that.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
Metal Mech
#24 Posted : 30 May 2017 22:51:26
That is a long drive for you. Much longer then for us.
Metal Mech
#25 Posted : 30 May 2017 22:54:35
Here is the first part of the head build. The eye is supposed to have a red decal but when I peeled it off it didn't have any sticky. Oh well not gonna stress about it.
Metal Mech
#26 Posted : 31 May 2017 05:03:13
Ok now for the final parts for the head. You will notice that there are two different skull caps and two different antenna. Bandai likes to include extra parts on the grunt mechs so that if you are so inclined you can army builds. The cap without the antenna slot are for grunts. The one with the slot are for the higher in command. It give the higher ranking officers better communication package and an easy visual identification on the battlefield. The difference between antenna are for captain/commander and the lower ranking officer. I don't know off had what their official designations are in the fictional universe. I could look it up if any is really interested in that information.
I choose the slotted cap and the higher ranking antenna because I like the look and it's what's on the box art.
This completes the head.
#27 Posted : 31 May 2017 08:07:33
Looking good ..Drool Drool
Metal Mech
#28 Posted : 01 June 2017 04:50:49
Up next are the legs. Here are the sprus I need to build the legs.
Metal Mech
#29 Posted : 01 June 2017 12:07:11
Time to start with the feet. Both are identical no difference between left and right.
Metal Mech
#30 Posted : 02 June 2017 00:03:28
Up next the ankle joints.
Metal Mech
#31 Posted : 02 June 2017 04:48:06
First part of the right leg.
Metal Mech
#32 Posted : 02 June 2017 05:18:14
Second part of the right leg.
#33 Posted : 02 June 2017 06:01:50
looking great Joel.Do you need to glue these parts together or are they just pressed together?
Metal Mech
#34 Posted : 02 June 2017 13:05:24
These kits are designed to be press fit. However you do find some pieces from time to time that could use a bit of glue. Usually on the smaller kits.
Metal Mech
#35 Posted : 03 June 2017 18:44:31
Updated photo. The last assembly just didn't feel right when I finished it. Then when I tried to work on the next step it wasn't feeling right either. So traced my steps back and noticed I had attached a section slightly off. Gonna chalk it up to late night speed building. The photo below is how it looks the correct way.
Metal Mech
#36 Posted : 03 June 2017 21:07:34
Third part of the right leg assembly.
Metal Mech
#37 Posted : 03 June 2017 22:11:55
Wasn't planning on showing another hose build after I did the first one but this one was a bit different. This time instead of it sliding everything over I had to connect a spring and a end piece and then slide everything over. Cool bit of work but a little fiddly to work with.
Metal Mech
#38 Posted : 04 June 2017 02:09:17
Fourth part of the leg assembly.
Metal Mech
#39 Posted : 04 June 2017 02:30:25
Fifth and final part of the right leg assembly. With this part finished I have completed my first spru tree. Quite a few more sprus will be empty after the left leg is done.
Metal Mech
#40 Posted : 04 June 2017 05:39:36
Since the left leg is exactly the same build wise as the right and this is a speed build. I decided not to post up photos of the build process. So here is a photo of the left leg complete and mounted on the rest of the body.
3 Pages <123>
This page was generated in 0.182 seconds.
