  impressive looking cannon barrels Magpie did u achieve that with just using blackener??
Hi Stuart,
yeah, I used the Blackener from CMB. I did the Barrels, the eyelets the rings and the caps. Saves painting lol..
Chris..On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi, Here are the finished article ready for rigging now. Chris..magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Rank: Pro  Groups: Registered
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
Damn they look good Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Hi All,
I have installed the name on the rear of the ship. Different font to the prototype but looks ok. Chris..Prototype.
Mine..magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 your choice of font definately looks better & more in scale than the 1st picture
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Really looks the buisness now that name plate is much better. I have finally surcombe and started mine now so will post pictures soon, still willnot be as good as your masterpiece. Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Damn, what a build. Far too embarrassed to put pictures of mine up now. My Victory look like after the battle of Trafalgar compared to your build. Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
nice paint job chris..very smart cheers benny
Hi All,
Thanks for the comments.. I think the letters quite suit it.. :)
Here I have installed all the cannons with the Breach rope attached... Ready for the next step.
I have started the blocks... Eyes are sore now getting late and squinting looking at these.. :D
I found that by getting a sheet of course wet and dry and a hard foam sanding block. You put a small block in between them and rub around on top of the wet and dry sheet lightly you can sand the blocks all the way round. The ones on the right are originals un sanded..magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 18/03/2010 Posts: 55 Points: 135 Location: Lordswood, Chatham
Looking fantastic Chris!
Hi .
Here is the latest update.. I have spent a couple hours here and there doing all the blocks for the cannons in between running around after my 6 kids, but am finally getting there with the cannons. I have one side done apart from the rope coils. But will make those all in one go. Once all done I can move onto the top deck.. Hurray. :) :)
Chris.magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
They look really good Chris. I can really appreciate how much work has gone into those cannon. I only had three a side for the Halifax and they took long enough and I still haven't added the train tackles at the rear.
Victory is going to be something else when I get that far!!
Mike T
Hi All,
Thanks for your comments Mike and Budgie, Yep the cannons are time consuming..Lol Its good stuff that blackener m8..
I have now finally completed the Cannons..Phew,, My next task is to start on the next deck and positions of the steps and the gratings. I have marked out and cut the holes out now. but no pics of the deck sorry.
Hi Again,
Been busy today...
First I marked out the steps on the main deck ready for the hand rail, then I installed the pillars and the chain pump handles. Then the stove in the correct position. Once all done fitted the top deck. All ready for the bulwarks to be planked now. Or do I plank the deck first..?
Looking really good Chris, all that hard work and patience is paying off
Thanks Mr T,
Its not looking too bad for only 30% of it being based on the instructions A/L give. I've done most from pictures of the Jotika Prototype also you don't get the Chain pumps, the stove and the elm tree pumps.. Oh and the top deck is not ply in the kit.. But that's what makes the more fun in making the parts yourself.
Hi all,
Well I've been a busy man today..Lol..
I masked the gaps up on the deck and the opening so I don't get too much saw dust under the deck. I the made the cut outs for the gun ports. and proceeded to make the frames. Then line the insides.
