106 Pages «<3536373839>»
#721 Posted : 31 May 2017 22:42:12
All templates fitted.
#722 Posted : 31 May 2017 22:47:39
I then had to remove sections of it to accommodate the vertical mdf supports. The cuts were rough but at this stage i just wanted to gauge how it looked and work out how i was going to strengthen and support it. Confused
The attached photos show were i had cut.
#723 Posted : 31 May 2017 22:54:27
Once i had the shell sitting about right within the torpedo compartment, i marked it's edge onto the inside of the planked hull. I proceeded to glue in plastic strip along that mark so that the edge of the shell had something to butt up against.
The attached photo shows the strips being fitted.
#724 Posted : 31 May 2017 22:56:22
This photo shows the shell being test fitted with it's edges butted up against the strips.
#725 Posted : 31 May 2017 22:57:54
Test fitting the shell.
#726 Posted : 31 May 2017 22:58:49
Another angle showing the shell and support strips.
#727 Posted : 31 May 2017 23:02:20
The next part was to fix strip at right angles to the existing edge pieces. By doing this the edge of the shell is fixed against a solid support.
#728 Posted : 31 May 2017 23:04:14
First edge support completed.
#729 Posted : 31 May 2017 23:07:16
By using the other half of the semi-circular templates, i could butt them up against the supports and begin to gauge the shape and size of the supports to fit underneath the shell.
This photo shows No.1 template being positioned.
#730 Posted : 31 May 2017 23:12:11
This photo shows one of the supports to fit under the shell where No.1 template is positioned. This piece, although simple looking, took nearly an hour to make. I had to continuously offer it up against the template to obtain the correct profile, while both were free floating and not fixed. Very time consuming!
#731 Posted : 31 May 2017 23:13:41
This photo shows the curved support and semi-circular template positioned in place
#732 Posted : 31 May 2017 23:15:41
I then glued the curved support in place.
#733 Posted : 31 May 2017 23:19:34
I used the same method to make the opposite side. Again, another hour!Blink
#734 Posted : 31 May 2017 23:22:07
Template being checked for fit.
#735 Posted : 31 May 2017 23:25:42
Once happy, i proceeded in the same sequence for No.4 template, the extra edging strip and curved supports.
This photo shows the extra strip fitted.
#736 Posted : 31 May 2017 23:28:15
Another angle showing the work so far.
#737 Posted : 31 May 2017 23:29:20
No.4 template being checked for fit against the curved supports.
#738 Posted : 31 May 2017 23:30:22
No.4 curved support fitted.
#739 Posted : 31 May 2017 23:31:47
This photo shows No.4 template being compared to the curved supports.
#740 Posted : 31 May 2017 23:32:43
Supports in place.
Guest (5)
This page was generated in 0.652 seconds.
