 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
now to attach this component. stevegbr attached the following image(s):
these two parts go together. stevegbr attached the following image(s):
now these two go together. stevegbr attached the following image(s):
this are attached. stevegbr attached the following image(s):
same as these two. stevegbr attached the following image(s):
this attached to the cover. stevegbr attached the following image(s):
now the second piece. stevegbr attached the following image(s):
now this is attached to the top of the engine. stevegbr attached the following image(s):
now to secure the top and bottom of engine together. stevegbr attached the following image(s):
here is issue 22. stevegbr attached the following image(s):
here are the parts for this issue. stevegbr attached the following image(s):
these components go together stevegbr attached the following image(s):
this part goes on next. stevegbr attached the following image(s):
these go together. stevegbr attached the following image(s):
screw this two together. stevegbr attached the following image(s):
end manifolds now attached. stevegbr attached the following image(s):
injectors put in place. stevegbr attached the following image(s):
now for the hoses to be fixed. stevegbr attached the following image(s):
here is part 23. stevegbr attached the following image(s):
Guest (11)
