3 Pages <123>
May's "memory lane" build Options
#21 Posted : 28 May 2017 17:12:45
Been looking at that myself May and it looks like you get a good set of parts in the first 4 editions to keep you occupied.
Looking forward to making a start on this one myself as well.
#22 Posted : 28 May 2017 19:25:32
BigGrin Hi May
Thanks for the heads up on the build and she goes together well the parts are laser cut so will need a light sand to remove the ash. Only a week to wait nowCool
MFG
#23 Posted : 29 May 2017 00:02:20
Hi Tony,
Yes it's nice to see this build getting underway, I've been keeping busy gathering all kinds of hints 'n' tips and know how's from around the web, I'm already having thoughts about doing the planking slightly differently....anyway we'll see BigGrin
May.
MFG
#24 Posted : 29 May 2017 00:11:54
Hi Andy,
Your more than welcome, been looking forward to seeing it BigGrin I'll be subscribing on the 5th so as you say not long to go now
May.
#25 Posted : 29 May 2017 07:32:16
MFG wrote:
Hi Tony,
May.
Hi May for your first build I would definitely stick to the official instructions as it might impact on the build further down the line
Looking forward to seeing your build Cool
MFG
#26 Posted : 29 May 2017 12:58:10
Hi Martyn,
You're right about following the instructions I have some idea on the way these builds are put together but reading about it and doing it are two different things.
My idea is to add the nails (tree nails?) instead of drawing them in. I've seen various ways to do this and it looks really effective so I'm going to have a go. In this instance if I mess it up I could take it of and relay it...... well that's the plan anyway Mellow
May.
#27 Posted : 29 May 2017 15:58:11
Blushing Sorry May got the wrong end of the stick I thought you meant the hull planking Confused . Looking forward to seeing what you do with the deck ThumpUp
MFG
#28 Posted : 29 May 2017 17:58:39
Hi Martyn,
No that was my fault, still leaning all the terms sorry for the confusion.
As for the hull planking I'll be following the instructions very carefully as it looks pretty scary Scared Scared Scared to me but I'll try my best.
May.
#29 Posted : 03 June 2017 15:08:15
Good luck with the build May. Look forward to seeing your progress.
Ian BigGrin
MFG
#30 Posted : 03 June 2017 18:25:52
Hi,
Thank you Ian, it's out on Monday so not long to go now BigGrin
May.
#31 Posted : 05 June 2017 09:51:09
Hi May,
I also have some sentimental memories of the USS Constitution.
Looking forward to following your build.
MFG
#32 Posted : 05 June 2017 12:12:24
Hi,
Thank you Garth, I've been gathering all kinds of tools and bits 'n' bobs so I'm all ready to getting started BigGrin
May.
MFG
#33 Posted : 14 June 2017 18:03:34
Hi,
So today is the day when this kit comes out for sale BigGrin
http://forum.model-space...spx?g=posts&t=22670
I've gone for the 24 month option, although I've ordered it today it will actually be a while before I get going with it as it's a busy time of the year for me and the school hols are just around the corner as well so it will most likely be September-ish when I make a start
May.
#34 Posted : 14 June 2017 19:11:56
MFG wrote:
Hi,
May.
Well done May
Look forward to seeing your updates when you do make a start.
#35 Posted : 14 June 2017 22:47:51
MFG wrote:
Hi,
May.
Gives you an opportunity to see how others progress first.
J
MFG
#36 Posted : 14 June 2017 23:17:29
Hi,
Thank you Tony and Jase,
Between the summer season, school summer hols and my hubby on home leave in August my time will be very much limited so I think putting it of is the best choice.
I'm looking forward to seeing your chaps diaries when you get going BigGrin
May.
MFG
#37 Posted : 19 June 2017 12:03:59
Hi,
Pack 1 arrived this morning, I wasn't expecting it until next week so that was a nice surprise but there were no instructions in the box at first I thought they had forgotten to send them but I have since learnt that you have to download them but I don't know were from, can anyone help?
Thanks May.
MFG attached the following image(s):
MFG
#38 Posted : 19 June 2017 12:15:47
Hi,
It's ok ignore my previous post I've found them now Blushing
http://www.model-space.c...constitution.html#build
May.
MFG
#39 Posted : 19 June 2017 12:32:10
Hi,
OK next problem I've downloaded the pack 1 pdf file but there are no pictures showing any suggestions?
May.
#40 Posted : 19 June 2017 15:40:59
Hi May
Finished work early today as this heat is too much for me - 83.5 degrees at my desk Confused
Just downloaded pack 1 from the site and all seems ok on mine. I am downloading on an ipad but would not have thought that would make a difference.
3 Pages <123>
This page was generated in 0.296 seconds.
