13 Pages «<56789>»
Panart 1/16 Victory Sloop Build Options
#121 Posted : 24 May 2017 17:29:30
BigGrin Very nice work AlanCool
#122 Posted : 24 May 2017 17:46:58
I do like your use of Danish oils on the wood Alan. Seen you use this before and it always looks so good.
#123 Posted : 24 May 2017 23:25:16
Thanks to all who looked in and for your comments, always appreciated....Cool Cool
#124 Posted : 26 May 2017 23:19:45
Continued to build up the rails to create the slots for the oars. This was actually a lot trickier than it looks. The sections are cut from a single 4 x 8mm limewood strip, the shorter sections didn't really pose a problem as the simple use of steam enabled the slight curves to be applied to follow the profile of the rails. However the bow was a different matter, steam wouldn't cut it here so decided to soak these pieces in boiling water for around 20 mins, then clamped them to the inside of the hull and left to dry fully. Doing it this way ensured the profile for the bow was being maintained. Once happy then glued everything in place...
Then moved onto shaping the top of the transom and have now glued the capping in place, just leaving this to dry fully before trimming and shaping.....Cool Cool .. Until next time, happy modelling.....
#125 Posted : 26 May 2017 23:30:07
Great tips for shaping the curves Alan, a superb build.
#126 Posted : 27 May 2017 11:39:10
Top class work again Alan. Doing an amazing job.
Chris Cool
jonny7england
#127 Posted : 27 May 2017 12:36:31
Been catching up Alan...Magnificent work...What a fine build mate!! Wink ThumpUp
#128 Posted : 27 May 2017 17:04:01
Hi Alan,
Such a clean and neat build. Your craftsmanship is something to aspire to.
#129 Posted : 27 May 2017 20:32:00
Very nicely done Alan
#130 Posted : 27 May 2017 21:26:37
Great job Alan, beautiful work.
sandnesspeats
#131 Posted : 27 May 2017 22:18:54
Hi Alan,
great build, makes a change for me to see your work
Very nice to see the progress.
Cool Cool Cool Cool Cool
cheers
rob
#132 Posted : 27 May 2017 23:14:43
Thanks for all the positive comments guys, always appreciated....Cool Cool
#133 Posted : 28 May 2017 08:48:07
Nice work Alan, very neat build. Love
#134 Posted : 28 May 2017 09:18:20
Thanks Mark, appreciated...Cool Cool
#135 Posted : 28 May 2017 10:52:37
So very neat and tidy.
Everything about the build looks wonderful.
#136 Posted : 28 May 2017 12:25:57
BigGrin Very nice work and a clean buildCool
#137 Posted : 28 May 2017 22:42:15
Thanks Tony, Andy, appreciated....Cool Cool
#138 Posted : 29 May 2017 08:06:54
Great solution creating the right shape! This build looks wonderful!
#139 Posted : 29 May 2017 22:53:00
Thanks Walter, appreciated as always....Cool Cool
#140 Posted : 29 May 2017 22:53:26
Decided to take a little break from working on the hull and moved onto to making a start on some of the fixtures and fittings, namely the bow barrel containing the rope for the anchor and the anchor itself. Started by taking two circular discs, 26 and 30mm and joining them together with a 12mm walnut block, had to ensure everything was central otherwise would end up with a wonky barrel. Once dried, cut strips from 1 x 3mm limewood and started to plank around the discs, some of the strips were made into wedge shapes to take into account the narrowing of the barrel itself. Everything was left to dry then given a couple of coats of clear varnish. Next, I applied the two bindings using thin thread and coated them with diluted PVA. Covered the top of the barrel with a coil of rope, glued in position with PVA.
The anchor itself came in two parts and these metal casts required a fair amount of cleaning up, lots of cast lines. Glued the two parts together with superglue gel, gave everything a coat of metal primer and painted black. Once dry attached the anchor to the anchor rope and secured with a couple of bindings. Am pleased with how it all turned out…..Cool Cool
Until next time, happy modelling….
13 Pages «<56789>»
This page was generated in 0.183 seconds.
