Raise 3d N2 printer Options
#1 Posted : 25 May 2017 14:57:58
My new 3d printer arrived.It is a beast weighing in at 138 pounds.It has a 12 inch by 12 inch by 12 inch print volume and has a resolution of down to 10 microns on the z axis and 12.5 on the x/y.
Here is a video of it in action.This piece was printed at 0.25mm resolution and it took 5 hours to print the part.
The part is for a full size 3d printed R2 D2.It will take several months to print this because it is split up into hundreds of pieces.
https://youtu.be/u2OlPAiVNHA
stevegbr
#2 Posted : 25 May 2017 15:02:23
very nice carl, you will have some fun with that, how long did it take to produce that item?
#3 Posted : 25 May 2017 15:08:28
It was a 5 hour print.The part is probably 8 inches by 6 inches by 1 inch tall.
This was on the lower resolution setting.The highest would have taken 8 hours.
stevegbr
#4 Posted : 25 May 2017 15:13:07
even low resolution its still impressive. love it. like to see more parts as you make them carl.
#5 Posted : 25 May 2017 15:16:02
Wow, looks like the printer is going to work overtime. I hope you don't have to stand and watch it.LOL
#6 Posted : 25 May 2017 15:45:50
That is a serious piece of kit but its certainly in the right hands to get the best from it.
#7 Posted : 25 May 2017 18:53:59
BigGrin Very nice and looks like the midnight oil will be burning to get that lot done. Bet all the stocks of fillament has gone short round by you nowCool
#8 Posted : 25 May 2017 19:09:45
It is quite mesmerising watching it go back and forth.I have a friend that has the bigger version of this printer and his last print was 72 hours long!! It was part of a wheel for a Mars Curiosity rover 1:1 display piece.
Nytetrain
#9 Posted : 25 May 2017 20:08:30
I was looking at the prices for these printers Scared Scared Scared It is a very nice piece of equipment though and the quality is superb. Some of the stuff I have received from Shapeways isn't as this good a quality as what you picture shows. How smooth is it? Some of the parts I have bought are terribly rough. I have always wanted to learn how to do this but the cost and space is somewhat prohibitive. Hope you have lots of fun with it.
Best Regards,
Ron
In the Stash: Losing count...
#10 Posted : 25 May 2017 20:41:58
Its pretty smooth on the 0.25 mm setting.You would still need a bit of sanding to make it really smooth.I havent tried anything on the 0.1mm setting .Apparently on that setting it is really smooth.
#11 Posted : 30 May 2017 17:39:30
I found a 3d model of the Mars Curiosity Rover put out by NASA .It is quite a large model and well detailed.I figured it would be a good test for the Raise 3d on it highest detail setting.So here is a print of one wheel and tire at 0.1mm resolution.The detail is very crisp and it doesnt need much in the way of sanding before painting.it took about 2 hours to print the wheel and tire.
#12 Posted : 30 May 2017 20:14:46
BigGrin Looking goodCool
This page was generated in 0.144 seconds.
