 Rank: Pro Groups: Registered
Joined: 20/03/2010 Posts: 113 Points: 342 Location: cheshire UK
Due to illness and bringing up a 1 year old my build has slipped behind. The stupid question is should the stern be flush across both sides or a slight gap between the 2 parts 34 i think??. Mag pics not very clear and do not want to sand off too much. Ayone help please
Hi comic123! The stern should be flush with the false keel no gap and keep it flush with the false keel all the way up to the stern gallery supports. Ok! As you start to sand the ash from the false keel stop you have removed enough of the transom hope this explains it for you mate.
many thanks, abit more sanding needed
