51 Pages «<1516171819>»
DaDokta`s Build Options
leedsfromsouth
#321 Posted : 18 May 2017 20:38:07
Great work , keep it going ...
#322 Posted : 18 May 2017 23:17:54
Great looking update and fab work on those cabin walls, very nicely done....Drool Drool
#323 Posted : 19 May 2017 07:08:53
Thanks guys! Glad you like it!
NikonD60
#324 Posted : 19 May 2017 22:42:10
Nice improvisation Walter. Looking good.
Alan.
Today is the tomorrow you wished for yesterday!
#325 Posted : 22 May 2017 00:07:47
Great work Walter.
Cool Cool Cool Cool
Congrats also on your "Orange" medal for 500 posts.
z8000783
#326 Posted : 22 May 2017 06:29:42
Groups: Unapproved
Beautiful and realistic, Walter.
#327 Posted : 23 May 2017 12:59:30
Thanks again! So here`s what i`ve done this Weekend.
First up was the ships`s wheel. I purchased Mike`s enhancement quite some time ago and i must say this one really makes a difference! Each wheel consists of 14 small parts.
As i was sure not to achieve a matching colour on the metal i decided to leave the wheels in bare metal, which gives a good contrast to the surrounding wood.
Also i corrected the backward wheel-support, added the steering-rope and the blocks through which they are guided as well as some painted details.
I added the decorations of the bulwarks and prepared the plastic sheet for the poop deck:
Finally i added the ledge (?) which runs from the cabin walls to the wheels (i guess that`s where the splinter guard was hooked in (?)) and scratch-built a mast-collar for the mizzen-mast:
#328 Posted : 23 May 2017 13:40:06
Great work WalterBigGrin love that wheel Drool regards PhilCool
darkwoodster
#329 Posted : 23 May 2017 13:54:12
Rank: Amateur level 2
That wheel looks fantastic. I wish these enhancement parts where still available. They add the icing to a great cake.
Do you mind me asking., why are you putting plastic under the deck? I'm intrigued :-/
Lovely build!
Neil
#330 Posted : 23 May 2017 14:23:55
Thanks guys!
@Neil
For once the plastic sheet gives the whole deck more stability (e.g. with the poop deck there`s a gap of several inches between the last deck-beam and the transom).
But the main purpose is that is use 4mm deck planks which i lay in a particular butting pattern (you can see this with my main deck). This is hard to do without a continous surface. Otherwise you could only butt two planks where there is a deck beam.
NikonD60
#331 Posted : 23 May 2017 14:41:16
The wheel looks great Walter. Keep up the good work.
Alan.
darkwoodster
#332 Posted : 23 May 2017 19:00:09
Hi Walter,
Thanks for clearing that up. It makes perfect sense now.
So is that the plank pattern of the real Victory decks?
Thanks,
Neil
#333 Posted : 23 May 2017 19:59:55
To my knowledge no one knows the exact planking pattern of the victory as it was in 1805.
I thinks there are much more experts in this forum than me who can tell you something about that topic.
I did a lot of research and especially read Wolfram zu MOndfeld`s "Historische Schiffsmodelle" - which is the german standard ouevre regarding ship-models - and he says that this was one of the (and certainly not the only one ) patterns used at that time.
What i can certainly say is that the plank-measurements i use (4mm width and 12cm lenght) is more accurate than the ones used in the instructions.
Who knows if it`s exactly right? I thinks the main issue is that you like what you built.
(by the way: advices regarding my english are always welcome as with all the very special naval vocabulary i just can hope that everyone understands what i am trying to say!) :)
#334 Posted : 23 May 2017 22:48:43
Excellent work Walter, the extra touches you're adding is making a great difference.... very well done....Drool Drool
#335 Posted : 25 May 2017 12:22:40
Hi Walter,
Great update. Your work on the cabin and ships wheel is outstanding.
#336 Posted : 26 May 2017 09:03:23
Thanks Alan, Garth!
This is some minor update.
I prepared the guns for the main deck, installed the first two guns - as the area won`t be easily accessible once the poop deck is installed - and glued the plastic base for the poop.
Next step will be planking the poop-deck.
#337 Posted : 26 May 2017 13:21:25
Cannons look great Walter, very nicely rigged....Cool Cool
#338 Posted : 26 May 2017 16:55:59
Another great update Walter Cool enjoying seeing your ship come together.
#339 Posted : 26 May 2017 21:27:23
BigGrin Nice work and looking goodCool
NikonD60
#340 Posted : 27 May 2017 13:45:56
Excellent work on the cannons Walter. I could not get the brackets straight on mine.
Alan.
Guest (13)
This page was generated in 0.218 seconds.
