13 Pages 123>»
Stevegbr E-type Jaguar Build. Options
stevegbr
#1 Posted : 21 May 2017 11:41:30
i will be starting this today, thought i would start with the wheel first, as that is what some people are having problems with. wish me luck. LOL
#2 Posted : 21 May 2017 11:47:23
Good luck with it. BigGrin
stevegbr
#3 Posted : 21 May 2017 12:34:56
thanks tony, just completed issue 4, so the first half of the wheel is complete, been told told issue 5 is worse.
Ian23
#4 Posted : 21 May 2017 13:09:47
good luck Steve, Mine isn't quite right but at least it's the spare and won't be particularly visible
Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Built: Deagostini Millennium Falcon
stevegbr
#5 Posted : 21 May 2017 14:47:53
issue 5 is no fun at all, got two spokes in and crossed A on the bottom and B on the top, spoke A fitted perfect, B seemed slight too short. took them out, will move them slight to the left and see if they fit better.
MFG
#6 Posted : 21 May 2017 16:23:37
Hi,
That's exactly what happened to me with the first set, 'B' seemed to short so I moved them to the right in my case, it was still a battle to push 'B' through the other spokes underneath but once though it fit perfectly.
May.
stevegbr
#7 Posted : 21 May 2017 16:45:15
not at all happy with this build, got half way round and the other pins started popping off, it does not seem well thought out in my opinion, and the thought of another four wheels is making me think call this one a day.
#8 Posted : 21 May 2017 20:31:18
Steve can you put a pic up as it may help present why you are having problems.
stevegbr
#9 Posted : 21 May 2017 20:37:53
i have broke it down now al, going to try a different approach.
#10 Posted : 21 May 2017 20:47:35
Okay, not to worry, have a look at the official build and the wheel tutorial as they may help.
http://forum.model-space...spx?g=posts&t=22456
http://forum.model-space...spx?g=posts&t=23122
#11 Posted : 22 May 2017 00:18:34
Sorry your having some issues with the wheel.Crying
I found that fitting spokes at opposite sides of the wheel helped even out the pressure and things stayed in place. Don`t know if this will help going forward, but it`s an idea.Blink
To cheer you up a bit, congrats on your "Purple" medal for 1000 posts.
Sorry it`s a bit late, Blushing Blushing.
stevegbr
#12 Posted : 22 May 2017 06:37:06
thanks for the flag derek, will have another go in a couple of days, fingers crossed.
mattsr
#13 Posted : 22 May 2017 11:11:31
I've superglued the spokes to stop them popping out. Might be worth trying.😊
stevegbr
#14 Posted : 22 May 2017 12:00:24
good tip mattsr, i have had a few tips off different members which i will try, thanks to those who messaged me as well. will keep you informed, just need a couple of days break, then go in with a fresh mind.. BigGrin
stevegbr
#15 Posted : 02 June 2017 16:05:30
i think i will have to buy parts 4 and 5 again, just cannot get the superglue out of the wheel, tried a couple of solvents to no avail, so its back to the drawing board, will have to think about if i want to continue with this build, it really is not fun.Cursing
#16 Posted : 02 June 2017 23:20:17
Sorry to hear that Steve, did you take any pics at stage 4 and 5 of your build I could take a look at.
stevegbr
#17 Posted : 03 June 2017 07:11:01
the first side went ok, thats why i superglued them in, but with all the pulling on the opposite side, a few had popped out, so i tried a couple of solvent removers so i could reset the pins but no joy.
stevegbr
#18 Posted : 05 June 2017 08:38:10
any idea when issues 4 and 5 will be available to order as back issues. BigGrin
#19 Posted : 05 June 2017 09:22:16
Try contacting C/S, they should be able to advise and perhaps organise duplicates of issues 4 & 5 for you....
stevegbr
#20 Posted : 05 June 2017 09:30:10
thanks alan, will give them a ring this week.
13 Pages 123>»
This page was generated in 0.133 seconds.
