 Rank: Beginner Level 1  Groups: Registered
Joined: 03/09/2015 Posts: 8 Points: 27 Location: Canada (French)
What kind off glue is the best for the Senna MP4/4 ?
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
I can't specifically state anything about that kit as I haven't built it yet, but for plastic parts on model rockets I like to use Loctites two part plastic glue. I can post up the exact details when I get home if you like. It's very easy to use and has a nice strong bond. DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
 Rank: Pro Groups: Registered
Joined: 20/12/2016 Posts: 138 Points: 414 Location: Plant City, FL
Gentlegiant wrote:What kind off glue is the best for the Senna MP4/4 ? depends on what you need to glue to what, plastic glues will not work for metal, if i read the page right there are two kinds of non metal parts so you might ned two kinds of glue if you need to use glu on both kinds of plastic. have you got the kit yet ? the magazines should give advice on the types to use *IF* you even need them. my fallback for general stuff is locktite gel and weldbond. depending on the material and how fast i need it to set up.
The first months magazine goes through the different glues for this model.Which glue you need depends on what you are gluing.Plastic to plastic or plastic to metal
Joined: 25/09/2013 Posts: 112 Points: 308 Location: UK
I find this absolutely brilliant:- http://www.palmermetals....op/g-s-hypo-cement.html
It comes with a needle-thin applicator nozzle which means you can apply it in very small amounts, reducing the risk of getting it onto places you shouldn't....
