51 Pages «<1415161718>»
DaDokta`s Build Options
#301 Posted : 04 May 2017 22:48:26
That's a nice piece of work Walter, your efforts have not gone to waste.... well done....Cool Cool
z8000783
#302 Posted : 05 May 2017 06:04:42
Groups: Unapproved
Just gorgeous, Walter. Wish I'd have done that now. You might want to think about putting real trenails in for the main deck as well.
#303 Posted : 05 May 2017 11:30:15
Thanks guys!
@John: Actually i thought about that a long time but then decided not to show the nails at all. I don`t really think you can show them in the right scale - other than small pencil-dots - as i did it with the upper gun deck (which i dont`t find very beautiful).
I finally let my wife decide - and she said i should leave the deck as it is :))
z8000783
#304 Posted : 05 May 2017 11:50:53
Groups: Unapproved
You are right Walter, scale is the demon of doing these models at times but, on balance I thought it looked pretty good and daily easy to do.
The first picture is my completed deck and the second is one I took on the Victory's main deck a few years ago. I could have certainly made mine a little better using a smaller drill size.
BTW, you may need to refresh a number of times as I had to put up an attachment which doesn't seem to work on this forum and the owners don't seem minded to fix it. Sorry.
#305 Posted : 05 May 2017 12:59:49
Well i must admit your nails look pretty much like the real thing! Very beautiful!
But i still won`t go that way because i must admit it`s too much work for me - i already glued thousands of copper plates to the hull - i don`t want to drill hundreds of holes into my deck now! :))
NikonD60
#306 Posted : 05 May 2017 13:48:04
Been looking back through your build diary and you are doing an excellent job.
Keep up the good work.
Alan.
Today is the tomorrow you wished for yesterday!
#307 Posted : 05 May 2017 16:33:23
It can't be fixed hence why a new forum is under development 😊
#308 Posted : 05 May 2017 22:40:51
Thanks Alan!
#309 Posted : 09 May 2017 06:03:17
Hi Walter,
Well done on your planking. As we have come to expect from you - an excellent job.
#310 Posted : 09 May 2017 13:57:05
Thanks Garth!
#311 Posted : 10 May 2017 16:26:01
I really love how your deck has turned out Walter. Using a black base has really added to the effect of caulking showing through Cool
#312 Posted : 10 May 2017 17:12:57
BigGrin Looking goodCool
#313 Posted : 10 May 2017 20:20:29
Worth noting that Victorys upper decks actually come from a royal hatch and are neither the correct timber or the correct width. if you look at pics of the middle gun deck which has original planking you will see the tree nails all have little crosses on the top from the tool used to hammer them home.
your deck looks fabulous by the wayBigGrin Drool
#314 Posted : 15 May 2017 12:50:57
Thanks for the nice comments!
Now that i`m finished with my gun-tutorial i can post the next update.
I cut the portholes, lined the bulwarks and did some painting.
#315 Posted : 15 May 2017 13:15:24
That is looking very nice indeed.
#316 Posted : 16 May 2017 09:26:45
Thanks Tony!
#317 Posted : 18 May 2017 11:30:05
Next up were the cabin walls.
The real cabin parts look quite different then the ones supplied so i did some scratch build!
#318 Posted : 18 May 2017 12:06:06
i also realized that there was an additional companionway in front of the main cabin entrance.
As i read somewhere that this often was covered i simulated it with some kitchen towel. i wasn`t very careful because it will barely be seen once the poop deck is installed.
#319 Posted : 18 May 2017 16:10:44
Those changes to the paritions look really good.
Really like your deck colouring.
#320 Posted : 18 May 2017 19:34:59
Hi Walter,
Excellent work on the your main cabin.
regards Trev.
