Advice from veteran builders Options
Allan
#1 Posted : 24 March 2011 06:39:03
I am going down the route of natural woodBigGrin with the top of the hull in sapeli the lower hull in Peruvian Mahogany and the Wale's in Peruvian mahogany my question is what color to do the Real Keel and the Dolphin area in?
TIP
And for those that want to use the thin wood stain to avoid the stain bleeding all over the place stain all the planks and bits that you need the day before you need them and hey presto no bleedingBigGrin BigGrin BigGrin BigGrin
Allan
Son of Bulwark
#2 Posted : 24 March 2011 10:57:55
Hi Allan! Cool
I would say make the real keel, hawsehole, stem reinforcements and the area between the dolphin's match the lower hull planks. The dolpin's would be made to match the wales.
Allan
#3 Posted : 24 March 2011 11:58:18
Son of Bulwark wrote:
Hi Allan! Cool
the wales are the same color as the lower hull now lol so i was thinking the real keel the same color as the wales and the lower hull and the dolphin's a lighter color to make them stand outBigGrin
Son of Bulwark
#4 Posted : 24 March 2011 15:38:37
Hi Allan! Cool
So you've already fitted your wales ok! then you are right to think of doing the dolphin's another colour to make them stand out. When doing a natural wood finish you should workout the colours first, what woods will be used for the different section and what parts will need to be stained.
For me this means that what is painted black on the painted version e.g. wales & dolphins will be made from walnut then stained with a dark walnut stain to get a strong contrast as the lower hull is also walnut. I'm only using Lime, Maple and walnut, other parts will get stain to change the colour of these woods.
This page was generated in 0.117 seconds.
