Chris, Walter thanks for looking in, appreciate the kind comments.... Regards Alan
A little more progress has been done. Finished fitting the new internal frames and glued them in place. Next job on the agenda was to plank the outer stern, these were laid in a horizontal fashion. Once done moved onto to planking the internal stern section but this time planked in a vertical direction.  .. Finished covering the keel at the stern and the bow, this included the internal areas...  .. Until next time, happy modelling.... Regards Alan Gandale attached the following image(s):
Very neat work Alan. That internal stern planking looks real tricky but you have done a lovely job on it. Happy Modelling
 Very nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Superb work Alan  looking forward to the next instalment. Al
Thanks guys, more will be posted in the next couple of days.... appreciate the comments.... Regards Alan
That looks sweet. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great work Alan she's coming along nicely. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Derek, Chris, thanks for the kind comments, appreciated.... Regards Alan
A little more work on her where I started to build up the handrails. First task was to take four strips of 2 x 10mm walnut, two for outside the hull and two for inside. These then had to be bent to follow the profile of the hull and to do this I simply used the plank bender tool available through the ModelSpace Shop. Details can be found here: http://forum.model-space...spx?g=posts&t=22531
Once happy with the contours I then glued them in place, did this one at a time ensuring the glue was completely dry before fixing the next strip, trimmed the strips at the stern when done...  .. The rubbing strake was next, this was again single strips of 3 x 3mm walnut. Once again the planking tool was use to bend the strip to the required profile. Glued and clamped the strips in place and left to dry. Trimming at the stern will be done after I have fitted the capping, this is the next task so until then... Happy modelling all.... Regards Alan Gandale attached the following image(s):
Looking very nice Alan. Happy Modelling
That`s looking great!Greetings, Walter
Looking really good Alan. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks for commenting Tony, Walter and Phil, appreciated as always.... Regards Alan
Another fantastic update Alan. Doing a great job. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Stunned no work Alan Is the hull as delicate as it looks?
looking really good Alan Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Rank: Beginner Level 3   Groups: Registered
Joined: 15/04/2017 Posts: 27 Points: 74 Location: Rijeka,Croatia
Joined: 22/12/2015 Posts: 246 Points: 776 Location: Birmingham, AL, USA
Alan, Your planking work is beautiful. These smaller scales are great to work with. Tom
Thanks once again everyone for the kind comments, appreciated... Will be posting again very soon... @Dave, the hull is quite fragile until you get the second planking layer in place and even then it is easily cracked. As the build progresses and more pieces are added the hull gains in strength where now she is feeling fairly secure but am still handling with care... Regards Alan
