7 Pages <12345>»
Ian's E-Type build diary Options
Coser
#41 Posted : 15 May 2017 16:49:31
Ian23 wrote:
Hi Roy
Yes the seat back is padded and made of the same leather as the seat cushion
It looks to me like the leather on the seat back gets covered by the plastic of the support. I presume this is correct, but must admit, I hoped that the back of the seat would be leather showing. (Admittedly, I don't know what the real car was like, nor do I know if there is a further part to come that will cover this.)
Can anyone please enlighten me?
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
Ian23
#42 Posted : 08 June 2017 16:54:45
New month new parts this time we start on the engine
Build the Jaguar E-Type, Part 10
Parts with Issue 10
Manifold Assembly (upper half)
Throttle linkage
Shaft
Suction Chambers x3
Take the throttle linkage and the shaft and feed the shaft through the 2 small holes in the throttle linkage (picture 2)
Take the shaft and align it with the manifold assembly with the 3 holes at the top of the branching points and secure with 2 screws (picture 3)
Ian23 attached the following image(s):
Building: Deagostini R2D2, Eaglemoss Delorean, Deagostini E-Type
Built: Deagostini Millennium Falcon
Ian23
#43 Posted : 08 June 2017 17:22:05
Build the Jaguar E-type, Part 11
Parts with Issue 11
Manifold assembly (lower half)
Petrol feed pipe
Air balance pipe
Air cleaner
Take the assembly from stage 2 and fit it over the lower half of the manifold assembly. Press the 2 parts together and secure with 2 screws in the plenum chamber (picture 2)
Next take the 3 suction chambers from issue 10 and fit them into the matching holes on the top of the carburettors. Secure each with a screw (picture 3)
next take the petrol feed pipe and align the 3 holes with the 3 pegs in the assembly (picture 4)
next take the air balance pipe and ensuring the alignment is correct place it in the 3 holes on top of the manifold. secure from beneath with 3 screws (picture 5)
Finally take the air cleaner and making sure the label on it faces out away from the rest of the assembly push it firmly onto the 2 pegs in the plenum chamber (picture 6)
#44 Posted : 08 June 2017 17:29:34
Ian
Very nice update on your build.
#45 Posted : 08 June 2017 17:34:16
Nice update Ian, looking goodBigGrin
Ian23
#46 Posted : 08 June 2017 17:43:55
Build the Jaguar E-Type, part 12
Parts with Issue 12
Engine block and clutch bellhousing (right side)
Starter Motor
Distributor
This issue gives you the option to paint the engine block black and gold to more accurately match the original. I have decided against doing this for several reasons. it wont be very visible and the people I will show it too wouldn't know the difference anyway and I'm scared I will make a mess of it.
So, first take the starter motor and push it into the hole behind the clutch bellhousing. secure from beneath with a single screw. (picture 2)
next take the distributor and push it into the hole at the indicated and secure from beneath with a single screw (picture 3)
Next take the carburettor assembly from the previous 2 issues and, making sure the alignment is correct, push the 2 lugs in the assembly into the corresponding 3 holes at the top of the engine block. secure with 3 screws. (picture 4)
Ian23
#47 Posted : 08 June 2017 17:50:28
Build the Jaguar E-Type, Part 13
Parts with issue 13
Engine block with clutch housing (left side)
filter head and hose
Battery box
Again we have the option to pain the other half of the engine but again I'm not going too.
Take the assembly from issue 12 and the Filter head from this issue and push it into the indicated hole. Secure from behind with a single screw. (picture 2)
Take the battery box and the other half of the engine block and fit the battery box into position as shown. secure with a single screw (picture 3)
Ian23
#48 Posted : 08 June 2017 17:54:25
and with that another month comes to an end. I'm liking the look of the engine, Not as detailed as the delorean one admittedly but that's a monster!
nice to see that some of the electrics are going in already as well. Will have to see if i have any A23 batteries lying around
Ian23
#49 Posted : 08 July 2017 17:14:26
Another month another set of parts. And a cap this time Cool
Build the Jaguar E-Type, Issue 14
Parts With Issue 14
Engine Breather
Ignition coil (2 parts)
Ignition Lead
Dynamo
Dynamo end cap
Timing Chain Cover
Pully
Fan belt and Pulleys
First fit the thicker end of the Ignition lead into the notch at one end of half of the ignition coil. Fit the other half of the Coil trapping the lead between the parts. Fix the 2 halves of the coil together with a single screw (Picture 2)
Fix the Ignition coil to the Cylinder head assembly from stage 2 (Picture 3)
Fit the engine breather into the other 2 holes in the Cylinder head and fix from beneath with a single screw (Picture 4)
Next take the Fan belt and pulleys and align them with the timing chain cover. Fix from behind with a single screw (Picture 5)
Take the dynamo and fit it to the correct keyhole shaped hole in the timing belt cover and fix inside with a single screw. Align the cap and push firmly onto the dynamo. (Picture 6)
Take the large pulley and line it up with the correct position on the pulley assembly and fix with a single screw. Drive a collared screw into the timing chain cover (Picture 7)
Ian23
#50 Posted : 08 July 2017 17:28:47
Build the Jaguar E-Type, Part 15
Parts with Issue 15
Plug leads
Forward exhaust manifold
Rear exhaust manifold
Rev counter generator connector
Take the exhaust manifolds and attach them to the left side of the engine. Secure each with a single screw. (Picture 2)
Use tweezers to fit the rev counter into the hole in the exhaust cam cover. This is a tiny piece and alot of care should be taken (Picture 3)
Take the Cylinder head assembly and align it with the left side of the engine block. secure them with 3 screws. Push the lead from the battery box between the 2 posts and make sure the free end protrudes through the notch at the end. (Picture 4)
Take the pulley assembly and align it with the front of the engine block. Hold it in place and align the 2 halves of the engine block. secure with 3 screws (Picture 5)
Next take the ignition lead and push it into the central hole in the distributor. Next take the plug leads and push the cluster of connections into the remaining holes in the distributor. (Picture 6)
Take the rest of the plug leads over the top of the engine and fit the ^ plugs into the holes in the Cylinder head (Picture 7)
Ian23
#51 Posted : 08 July 2017 17:33:30
Build the Jaguar E-Type, Part 16
Parts with Issue 16
Passenger door
Door handle
Match the door handle to 2 holes in the outside of the door. Secure from behind with a single screw (Picture 2)
Ian23
#52 Posted : 08 July 2017 17:38:31
Build the Jaguar E-Type, Part 17
Parts with Issue 17
Passenger door window
Hinge
Hinge retainer
Take the door window and align it with the door assembly. Secure with 3 screws. (Picture 2)
Align the hinge and the hinge retainer. secure with a single screw (Picture 3)
Ian23
#53 Posted : 08 July 2017 17:42:16
well another month down and we have a complete engine block. the passenger door appears to be exactly the same in construction to the drivers door. Looking ahead it looks like we start on the sub frame next month with will be good.
Can't wait for it to actually start looking like a car LOL
#54 Posted : 08 July 2017 22:47:52
Looking good Ian, waiting for the next set of parts is the hardest part of the build BigGrin
Ian23
#55 Posted : 09 July 2017 08:48:39
Hi Al,
Yes it is. It always is! I always get to the end of the months issues and just wish I had more to do!
Ian23
#56 Posted : 12 August 2017 17:46:28
Another month and whilst not as much to do this month it's all moving along.
Build the Jaguar E-Type, Part 18
Parts with Issue 18
Passenger door trim surround
Passenger door trim panel
Passenger door handle
Passenger window regulator handle
Chrome finisher (upper)
Chrome finisher (lower)
Arm rest
Take the door assembly from issue 17 and the door trim surround. Push them together and secure with 4 screws (picture 2)
Take the door trim panel and the arm rest, Noting the arm rest orientation fasten together with 2 screws (picture 3)
Take the door handle and the window winder and, ensuing they are in the correct place and orientated correctly, secure each with a single screw from behind (picture 4)
Take the trim panel and push it into the door assembly (picture 5)
Take the trim sections and push them into the slots in the door interior (picture 6)
Ian23
#57 Posted : 12 August 2017 17:49:35
Build the Jaguar E-Type, part 19
Parts with issue 19
Right hand inner side member
Nothing to do with this issue so just keep the part ready for the next issue
Ian23
#58 Posted : 12 August 2017 17:53:59
Build the Jaguar E-Type, Part 20
Parts with Issue 20
Right upper wishbone
Right lower wishbone
Right suspension upright
Take the inner side member from issue 19 and align the 2 wishbones as shown. Take the suspension upright and fit it over the 2 pivot points on the wishbones and secure it too the side member with 2 screws. (picture 2)
Ian23
#59 Posted : 12 August 2017 17:56:01
Build the Jaguar E-Type, Part 21
Parts with issue 21
Left hand side member (inner frame)
Again nothing to do in this issue so just keep the part too one side ready for the next issue
Ian23
#60 Posted : 12 August 2017 17:57:26
well another month down and we have started on the internal frame work. Next month should be good with the framework getting completed
7 Pages <12345>»
This page was generated in 0.375 seconds.
