16 Pages «<89101112>»
Eaglemoss Delorean Options
spike
#181 Posted : 12 May 2017 16:44:15
Insert the two pins on the starter 2 into the holes on starter 1. Place the starter up against the front of the engine and add an AP screw.
spike attached the following image(s):
Building - Suzuki GSX 1300R, Hummer, Ford Mustang, R2D2 Droid, Delorean.
Finished Builds - Nissan GTR, Millennium Falcon.
Other model kit builds - Tamiya RC Trucks, Tamiya RC cars
Thanks for looking.
Duane
spike
#182 Posted : 12 May 2017 16:46:43
Place the engine bottom underneath the front of the engine and fix in place with 2 JM screws.
Thanks for looking.
Duane
spike
#183 Posted : 12 May 2017 16:59:14
Issue 18
Parts -
Engine Back
Engine Side Right
Engine Side Left
Fuel Filter
Oil Filter
Manifold Right
Manifold Left
6x DM Screws
6x AP Screws
Thanks for looking.
Duane
spike
#184 Posted : 12 May 2017 17:07:36
Secure the fuel filter onto the right engine side with an AP screw. Do the same with the the oil filter.
Thanks for looking.
Duane
spike
#185 Posted : 12 May 2017 17:14:32
Attach the right manifold (has a hole in the middle) to the right engine side and add 2 AP screws. Attach the left manifold to the left engine side with 2 AP screws.
Thanks for looking.
Duane
spike
#186 Posted : 12 May 2017 17:21:11
Fix the right engine side to the engine bottom with 2 DM screw. Do the same with the left engine side. Then add the engine back to the engine bottom and add 2 DM screws.
Thanks for looking.
Duane
spike
#187 Posted : 12 May 2017 17:40:01
Issue 19
Parts -
Engine Top
Auxiliary Air Pipe
Pipe
Water Hoses
Water Pump
Water Distribution Pipes
3x AP Screws
4x AM Screws
Tweezers
Thanks for looking.
Duane
spike
#188 Posted : 12 May 2017 17:47:08
Fix the water pump to the water hoses with an AP screw. Push the ends of the water hoses into the engine top, turn the engine top over and add 2 AP screws.
Thanks for looking.
Duane
spike
#189 Posted : 12 May 2017 17:54:00
Attach the water distribution pipes the the engine top and add 3 AM screws. Fix the auxiliary air pipe on to the engine top and secure with an AM screw. Add the pipe onto the auxiliary air pipe.
Thanks for looking.
Duane
spike
#190 Posted : 12 May 2017 18:03:16
A few pic off the last 2 issues of the Thunderbird 2, issues 3 and 4.
I am very happy with the way it looks and can't wait till they bring it out. I don't like how the people are no use for them if all the vehicles are going to be on a display case.hey should add people that can sit in the seats that would be better.
Thanks for looking.
Duane
#191 Posted : 12 May 2017 20:23:13
The engine parts on your car look nicely made.
Hope it continues to go well.
spike
#192 Posted : 18 May 2017 12:55:25
Hi birdaj2 the engine parts are good but in some parts their are gaps witch need filling in with some filler but apart from that the parts fit together nicely.
Thanks for looking.
Duane
spike
#193 Posted : 18 May 2017 12:59:15
Issue 20
Parts -
Left Air Intake
Right Air Intake
Intake Bottoms x2
Intake Manifolds x3
16x AP Screws
Thanks for looking.
Duane
spike
#194 Posted : 18 May 2017 13:08:34
Push the 3 intake manifolds into the holes in the 2 crosspieces (do one at a time and make sure the 2 intake bottoms are the same way) then fix together with 6 AP screws.
Thanks for looking.
Duane
#195 Posted : 18 May 2017 13:10:19
Its all progressing very nicely.
spike
#196 Posted : 18 May 2017 13:17:53
Fix the right air intake to the intake bottom and add 2 AP screws. (Note the right air intake has a grove and a curved section at one end)
Add the left air intake in the same way.
Thanks for looking.
Duane
stevegbr
#197 Posted : 18 May 2017 13:20:05
Looks great spike. I take it you are enjoying the build.
spike
#198 Posted : 18 May 2017 13:25:05
Insert the assembly into the top of the engine aligning the holes of both sub-assemblies then add 6 AP screws.
Thanks for looking.
Duane
spike
#199 Posted : 18 May 2017 13:27:50
Thanks birdaj2 its coming along nicely the engine is big and got some weight to it.
Thanks for looking.
Duane
spike
#200 Posted : 18 May 2017 13:30:58
Hi stevegbr thanks yes the build is good and alot has been done saying its only were only on issue 20. How are you finding the build?
Thanks for looking.
Duane
This page was generated in 0.485 seconds.
