7 Pages «<34567>
1/43 scale Bedford HA Van Options
#81 Posted : 11 May 2017 23:30:22
Good Evening and a very late night post from me but I couldn't help myself after the progress I made earlier.
I have successfully made my very own DIY water slide decals. They have turned out very well and i'm sure Brian will be blown away when he sees his logo in miniature.
If anyone is interested in how I made them I will start a 'How To' thread in the relevant section of the forum.
The attached photos show the actual van and then the model. I'm so happy with the decals!BigGrin
Bedford HA van.JPG (266kb) downloaded 29 time(s).
#82 Posted : 11 May 2017 23:34:50
Bedford HA van.JPG (266kb) downloaded 28 time(s).
#83 Posted : 11 May 2017 23:38:23
I then painted in the window seals. This didn't turn out 100% first time as I had 'bleed through' from the masking tape. I then had to re-touch with a fine magic marker to correct the lines adding a bit of white where the seals were too thick.
The results turned out reasonably well.
#84 Posted : 11 May 2017 23:40:12
Next up I fitted the glazing. I chose to cut it so that the passenger window is fully open and on the drivers side the window is wound half way down.
#85 Posted : 11 May 2017 23:42:00
I downloaded an actual tax disc from 1977 and resized it to the correct scale; about 2.5mm in diameter, so very small. The edges look a bit ragged but this is a close up photo and when viewed in real life you would hardly notice.
#86 Posted : 11 May 2017 23:44:09
Well that's it for tonight's HA van build log.
More posts to follow soon.
Thanks for looking in, have a great weekend and happy modelling.
#87 Posted : 12 May 2017 06:26:03
Looking good
#88 Posted : 12 May 2017 07:09:23
That really takes it to the next level with the markings you have made.
They look absolutly brilliant.
#89 Posted : 12 May 2017 09:10:39
jase wrote:
Looking good
Cheers Jase, your comments are appreciated. Thanks for looking in.
#90 Posted : 12 May 2017 09:12:16
Thanks very much Tony. Very happy with the decal results!BigGrin
#91 Posted : 12 May 2017 11:27:10
Excellent painting PhilBigGrin really looking greatDrool regards PhilCool
#92 Posted : 12 May 2017 16:01:34
Thanks Phil. Much appreciated!BigGrin
#93 Posted : 12 May 2017 16:25:56
Excellent work Phil, I'll take a look at the "know how"
#94 Posted : 15 May 2017 09:29:26
Thanks for looking in Mark. I haven't started the 'How To Make Your Own Water Slide Decals' tutorial yet. It'll be up and running within the next month.
#95 Posted : 15 May 2017 11:21:24
Looking fab Phil, your efforts are certainly paying dividends.... very well done...Drool Drool
#96 Posted : 15 May 2017 13:35:59
Thank you very much Alan. Your comments are appreciated. The deadline for completion is Wednesday evening but I feel confident it will be finished a day earlier.
Phil w.
#97 Posted : 15 May 2017 13:49:11
Phil w.
Phil
And i am looking forward to seeing it in its fill glory.
I am very impressed with how you have built this one as the detail and enhancements really are top notch.
#98 Posted : 15 May 2017 13:49:20
Phil w.
Phil
And i am looking forward to seeing it in its full glory.
#99 Posted : 15 May 2017 23:03:26
Phil w.
Phil
Thank you Alan. The wait is over!
#100 Posted : 15 May 2017 23:09:50
Evening Fellow Modellers,
More progress has been made on the Bedford HA van.
I decided to build my own scratch built wind screen wipers as the originals were moulded into the windscreen and had no definition.
I used 0.8mm half round plastic rod for the wiper blades and 0.8mm round plastic rod for the arms and 1.0mm diameter rod where the arms attach to the body.
I painted the wiper rubbers as one length in matt black before cutting to size and gluing to the windscreen. The arms, similarly to the rubbers were made as one length, painted in aluminium with a small round of the 1.0mm rod glued to each end of the rod. When dry, I cut the rod in half and then trimmed the arms to the correct length.
I have to say that i'm very happy with the end result.
7 Pages «<34567>
